Indy 360 head (Magnum Application)
#856542
11/18/10 02:50 AM
11/18/10 02:50 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Anyone know or have experience using Indy's 360 heads in a Magnum application? What I want to know is do they (or can they) have the correct number of bolt holes and spacing in the ends of the heads for the Magnum accessories? I found these but they only mention that the kit uses magnum Pushrod oiling. Which doesn't cover all the differences for using them on a Magnum Motor. http://www.usaperform.com/indy-small-block-chrysler-magnum-kits-1992up-p-1018.htmlWas curious!!! I know they will fit the blcok and work, but will they accept all the extras?
Re: Indy 360 head (Magnum Application)
[Re: DakFink]
#856543
11/18/10 11:15 AM
11/18/10 11:15 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
LA and magnums have the accessory holes on the end in the same place, but the magnums are all on the same plane,and the lower outer one on an LA is about 1" rearward. worst case, you may have to use a spacer and longer bolt for whatever bolts in that location on a magnum.
you could also drill the cam journals and use LA cam bearings on the magnum to oil LA style
[Re: ADakotaRTGuy]
#856552
07/26/11 09:55 PM
07/26/11 09:55 PM
Posts: 13 Oxford, OH
Blue93Dakota
Oxford, OH
They don't work easily from what I have experienced so far. Be ready to fabricate. There is not much thickness on the end face of the head. I drilled one hole to tap it and wished I didn't.
93 Dakota Club Cab
R3 Turbo Build in progress
