Re: 2 Stage Nitrous system setups?
[Re: 70satelliteguy]
#856322
11/17/10 10:28 PM
11/17/10 10:28 PM
Posts: 1,200 UK
602heavy
UK
I use the NX pro power shark plate , this is a two stage SINGLE plate (500/300) , centre bar sprays 300 & perimeter sprays 500 , IMO the solinoid does'nt support the 500 shot due to orifice size but that's something else , this is what i use although plenty more vendors out there. Obviously a fogger would be the way to go.
[Re: 4404dart]
#856326
11/18/10 11:48 AM
11/18/10 11:48 AM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
I had a Monte Smith fogger, then the rules changed to allow a second stage, so I added the plate. 2 foggers would be ideal, but expensive, the double crossbar mentioned would probably be the best bang for the buck. Monte will give you a honest answer to what you want.
That is alot of plumbing going on in there.
[Re: silverfish]
#856328
11/18/10 03:00 PM
11/18/10 03:00 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
You asked if a fogger was that much better.
ABSOLUTELY!!
