Question about column shifter linkage #855744
11/17/10 01:43 AM
11/17/10 01:43 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
When installing a big block and a 727 in an A-body that is a column shift automatic, what linkage would be rquired? Would the linkage from a small block with a 727 be the same or would you need to use the column shift linkage from a B,C or E-body with a big block?
Re: Question about column shifter linkage [Re: 1970RT] #855745
11/17/10 11:08 AM
11/17/10 11:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You need the A body specific linkage, and just so you know very few if any column auto Big block cars were built and they would only be 383 cars.
Plan on modifying something to fit , start with A body 727 , again good luck finding that one also.
Re: Question about column shifter linkage [Re: JohnRR] #855746
11/17/10 11:48 AM
11/17/10 11:48 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
A 383 with a 727 is what I need the linkage for. I want to keep the column automatic shifter when I install the big block combo. If I got a set of 318/340/727 linkage would it just be a matter of lengthening some of the rods or would it be more involved than that? Are the parts that actually connect the linkage to the trans. different?
Re: Question about column shifter linkage [Re: 1970RT] #855747
11/17/10 12:09 PM
11/17/10 12:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The length of the Z bar is going to be much shorter , I can't tell you if the other parts are different because I have NEVER seen them. The only way to know what fits exactly is to mock it up and see what you need to change.
Re: Question about column shifter linkage [Re: 1970RT] #855748
11/17/10 12:51 PM
11/17/10 12:51 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
I'm gonna need the same thing, but in a '72 B-body. SB/904 to a BB/727 column shift linkage. Good luck.
