wicked 440 build up ideas?
#85566
07/07/08 11:03 PM
07/07/08 11:03 PM
ok what would be a quick boost in power ive put cam intake carb ignition indexed plugs played with timing all kinds of stuff i was thinking about puttin in an underdrive kit any body used a good under drive kit? im gettin the nos sniper kit 359.99 or somethin like that ok and what about fuel and oil coolers a demon carb performer rpm intake instead of torker 2 i just want some ideas i can reuse when i pull the engine out this winter oh and its a 440 with a lunati 60302 cam and spring kit what about a turbo i wanna go kinda crazy here any body ever used one
Re: wicked 440 build up ideas?
[Re: MikeyT]
#85568
07/07/08 11:24 PM
07/07/08 11:24 PM
yea i was planning this build for another car but i want something COMPLETELY DIFFERENT for this build thats why i was asking about turbo and stuff cuz how many 440s do you see with a turbo? i want a crazy build just one nasty 440 thats nobody ever seen before untill i turn it into a 543
#85569
07/07/08 11:31 PM
07/07/08 11:31 PM
oh come on people nobody ever had anything they wanted to try on a 440 any ideas at all...MONEY IS NO PROBLEM i want just plain crazy ideas to build power and be different!!!!
#85570
07/07/08 11:53 PM
07/07/08 11:53 PM
send me $17000 and i'll ship you the CRAZIEST 440 you've ever seen.
#85572
07/08/08 12:44 AM
07/08/08 12:44 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
www.1962to1965mopar.ornocar.com/mmo82001.html
[Re: Triggerfish]
#85573
07/08/08 12:49 AM
07/08/08 12:49 AM
#85574
07/08/08 04:05 AM
07/08/08 04:05 AM
i want to build on even more bada** that that and that is sweet!!!i loveing the ideas keep them comeing .i want it fast REAL FAST.
#85575
07/08/08 08:52 AM
07/08/08 08:52 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
well boost it and instead of NOS get a meth-H2O injection kit. You won't even need a cooler. I'd probably supecharge it. Easier and you don't have to hack up your engine compartment. If you're talking about a basic 440 for the street. Get a set of good light rods/pistons, roller cam, E-heads (or similar), headers, RPM intake, Holley 950DP, and a stall and gear to match your cam. Then hit it with a 200 shot. Depending on you car and the set-up your could be in the 9-10 second range.
[Re: Mr.Yuck]
#85576
07/08/08 09:56 AM
07/08/08 09:56 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Gunnar, your posts come off as the wild rantings of a teenager that has big dreams. If you spend a little time here reading, there are some wild motors already. A twin turbo street car, a C body that's deep in the 8s, a 632 Cu In. drag motor. If you really do have unlimited funds and want to build an outrageous motor, why would you post about building more power without rebuilding? https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=4445835 Then ask about a common torque spec? Do I need to go on? Define what intended use you have in mind, a realistic budget, and ask what people suggest. You will get integlligent, informed answers.
[Re: moparmojo]
#85578
07/09/08 12:05 AM
07/09/08 12:05 AM
DaytonaTurbo
Manitoba, Canada
Do a turbo then. STSturbo does the rear mounted turbo setups. Run it with a small amount of boost, say 5-7 psi, then when you rebuild, crank it up higher. But in reality, you are probably better off saving your money towards rebuilding the motor itself. You can buy the goodies now that you'll reuse like carb, intake, headers, aluminum heads, etc so that when rebuild time comes, it's easier on the wallet.
