572 hemi in a street car #855540
11/16/10 08:48 PM
11/16/10 08:48 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I have been looking at getting a 572 hemi for my 73 cuda that is going to be a street car with a trip to the track every now and then. Any thoughts on if this will be too much motor for a street car? Gas milage obviously isnt a concern, I just dont know if this will be something that will do nothing but sit there and spin whenever i want to get on it and be useless without a pair of slicks. Was considering maybe a 528 hemi too. Car currently has a 340 that i built for it. Any thoughts?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 572 hemi in a street car [Re: 73cuda340] #855541
11/16/10 09:00 PM
11/16/10 09:00 PM
K
kielbasa Offline
kielbasa  Offline
K
it'll have a little more than the 340, maybe not night and day, but noticeable.
if it's gonna be a street car, forget the slicks. whole lot more fun sliding around corners, etc.
half the fun driving these old mopars is fighting with the steering trying to keep the thing in a straight line while showing off.....
Re: 572 hemi in a street car [Re: 73cuda340] #855542
11/16/10 09:29 PM
11/16/10 09:29 PM
AndyF Offline
AndyF  Offline
The 528 with a single carb on a dual plane intake should be very street friendly.
Re: 572 hemi in a street car [Re: AndyF] #855543
11/16/10 09:55 PM
11/16/10 09:55 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
it depends how it's built, what gears are in the rear, and how hard you drive.
i have a daily driver 572 hemi in my 72 road runner. low compression, single plane indy intake and still makes 500 lbs torque at 1500 rpm. if you drive it reasonably it gets around 14mpg on the highway.
you have to ask yourself what exactly you want and build accordingly.
perception is 90% of reality
Re: 572 hemi in a street car [Re: 73cuda340] #855544
11/16/10 11:29 PM
11/16/10 11:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
From a 340 to a 528/572 Hemi is quite a step. Have you had cars with that kind of power before? Do you have the suspension and drive train that will handle that kind of power? If not set up right, then the car could be a real handful. Or even dangerous.
I personally have had big blocks all my life. Driven and raced them for 30 years. A few years ago I built an Eddie headed 500" stroker. It is a different animal altogether. Even now, with a good suspension set-up, it can break the tires loose at 45 mph if I am not careful. Things happen very fast with this level of power. And you will probably have even more horsepower given the additional inches and the fact that it's a Hemi.
If possible, you may work your way up to that kind of power a little at a time. That way, you your drive train and your suspension can get up to speed.
Master, again and still
Re: 572 hemi in a street car [Re: 73cuda340] #855545
11/17/10 12:41 PM
11/17/10 12:41 PM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
Go for it. I put a 528 maxx aluminum hemi, 1050 dominator with 5 speed overdrive and 430 rear in my 72 cuda. What a rush. Can easily get away from you. Problem is you can't get enough tire under it. Have put sub frame connectors on it. This is a street only car.
Re: 572 hemi in a street car [Re: kielbasa] #855546
11/17/10 02:14 PM
11/17/10 02:14 PM
michigan woods
imfixinmopars426 Offline
michigan woods
a little more? i be afraid if it hooks hard the windshield would pop out,and break the seat back...lol..
Re: 572 hemi in a street car [Re: imfixinmopars426] #855547
11/17/10 03:35 PM
11/17/10 03:35 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Either motor will do the trick. For the last couple years I've been finding and upgrading the 'weak links'. I plan on putting some bigger street rubber under the truck in the coming year. It will smoke the tires at any speed up to 70 right now. I opened up the wheelwells to fit a pair of 32.5x14 radial drag slicks.
In any case either motor will at one point scare you into wishing you had a pair of depends on.Dave
Re: 572 hemi in a street car [Re: imfixinmopars426] #855548
11/17/10 03:52 PM
11/17/10 03:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Broken windshields and wrinkled quarter-panels....ahhh, the price we pay for performance. There's an old saying, "Speed costs money, son. How fast do you want to go?"
Is bigger always better?
I was going to build a big old 550+ cubic inch sixpack motor, but decided to just build a little 493 inch motor because of the above mentioned items. As it is, it puts out close to 700 horsepower at 5500 rpm, and I'm still worried about those things.
I had to spend a lot of money upgrading all the links in the chain to handle that horsepower level, fuel system, ignition system, exhaust, driveshaft, subframe connectors, and Cal-tracs. With todays DOT legal drag-radial tire technology, hooking up is going to be possible, but tire life short.
Something to think about when deciding....One time I had a 500 horsepower 440" 'Cuda do an nearly instantanious 180 degree rotation at 45 mph when I popped the clutch it in 2nd while punching it. My buddy still talks about that to this day. We spun out onto the freeway backwards in a cloud of smoke. Got lucky that day. I never had that car do anything like that in the hundreds of times I'd done that before. Note to self, be f'ing careful with big horsepower.
Re: 572 hemi in a street car [Re: jbc426] #855549
11/17/10 04:31 PM
11/17/10 04:31 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I'm running a 528 Hemi on the street that has a mild cam and 850 carb. It's pretty much like driving a big block except it makes you wish you had a spare set of shorts when you nail it. :biggrin
Re: 572 hemi in a street car [Re: 73cuda340] #855550
11/17/10 04:58 PM
11/17/10 04:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess I don't see the need for all of that. If you just want a cool street car why not a 426 or 472? As mentioned all that motor is going to require some serious mods to get it to stick. Why not do a blown hemi for that matter?
Coming soon!!!!
Re: 572 hemi in a street car [Re: 73cuda340] #855551
11/17/10 06:18 PM
11/17/10 06:18 PM
I have been looking at getting a 572 hemi that is going to be a street car Any thoughts on if this will be too much motor for a street car? Gas milage obviously isnt a concern, I just dont know if this will be something that will do nothing but sit there and spin whenever i want to get on it and be useless without a pair of slicks. Any thoughts?
Do it. You'll be able to use as much or as little of the power that will be available to you with it and as said w the tire tech avail nowadays you can get it to hook. I haven't met anybody yet who after the fact wishes that they didn't have that much power at their disposal in fact just the opposite they wished they'd have built a killer right from the getgo.
Re: 572 hemi in a street car [Re: 73cuda340] #855552
11/17/10 07:43 PM
11/17/10 07:43 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
You're welcome to come drive mine
Re: 572 hemi in a street car [Re: CRE2004] #855553
11/17/10 08:58 PM
11/17/10 08:58 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
As we've stated above, big horsepower can get you in trouble real quick, you really have to be aware of the conditions and surroundings.
The very first time I drove my truck with the 528 under the hood I darn near killed myself. -25F., I decided it would be safer to run it up to 70 before nailing it. It instantly started spinning the tires, I used up both lanes and shoulders before I could get it straightened out enough to get off the throttle.
The biggest problen as I see it though is...you get used to the power pretty quick and then want more. That's the main reason I bought a Dyno, the need to find more hp. Horsepower....more addictive than Heroin. Dave
Re: 572 hemi in a street car [Re: quickd100] #855554
11/17/10 11:58 PM
11/17/10 11:58 PM
clarks summit pa
clarks summit pa
How is everybody else hooking up with their cars and the hemi's?
Re: 572 hemi in a street car [Re: 73cuda340] #855555
11/18/10 12:26 AM
11/18/10 12:26 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I've got a 472 Stage V in my car. I run a stock convertor and 3.23 rear gears along with a stock exhaust system. That tames it alot but it's still easy to spin the tires from here to Mexico. I like the bigger cubes in a street car because you can get very good performance from it but with lots of tractability and lower revs. I've had at least 1 at a time Hemi since 1980 and the stroker crank is the way to go with a Hemi on the street.
Sheldon
Re: 572 hemi in a street car [Re: 73cuda340] #855556
11/18/10 01:48 AM
11/18/10 01:48 AM
QLD Australia
Keith Black® Offline
QLD Australia
Darren Beale
Keith Black Racing Engines®
Re: 572 hemi in a street car [Re: Keith Black®] #855557
11/23/10 11:19 PM
11/23/10 11:19 PM
clarks summit pa
clarks summit pa
Anyone else?
Re: 572 hemi in a street car [Re: 73cuda340] #855558
11/24/10 12:30 AM
11/24/10 12:30 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
'68 Hemi RR, 4-speed, 4.10, 438", 540HP & a bit over 500ft/lbs before the carbs were straightened out. Not a prayer of hooking up on the street until 3rd gear if the 295/50R15s T/As are mounted. With M&H DOTs on it it's a lot better, but you can still break 'em loose bigtime clutching it in 1st gear. Before the car was restored, it had cracks at the cowl from street racing it; you could see the car twist when powershifting. There's more rear weight bias on my car than an E-body.
The other thing to keep in mind is slowing it down; My 11" drums are fine until 3rd gear wide-open, so ya gotta pick empty places to let it out.
Re: 572 hemi in a street car [Re: Keith Black®] #855559
11/24/10 12:44 AM
11/24/10 12:44 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We run a couple of Hemis on pump gas, and getting the rest of the car to survive them is usually the biggest issue. The little 477 pump gas street Hemi in the Charger has killed 4 rear ends, 1 drive shaft, a set of brakes, 10 wheel studs, and a set of leaf springs, and a set of seat brackets....That little engine has pushed the 4010lb Charger to 11.1 at 122mph and a 1.58 60ft...
My 484 Hemi in my Cuda has killed just about everything from kinked quarter panels to inner fenders torn off the frame rail, to crushed oil pans, crushed headers, cracked window glass, de-arched leaf springs, broken pinion snubbers, and a gawd aweful amount of rear tires....Should go 9's, but I always break somthing.
A 572 will do all that and more I am sure...
