affect of valve stem on air flow #855161
11/16/10 11:50 AM
11/16/10 11:50 AM
New Jersey
barryc Offline OP
barryc  Offline OP
New Jersey
Is there a way to figure out what affect the diameter of a valve stem would have on air flow?
Currently have 3/8 valves and thinking of going to a 5/16 stem.
Re: affect of valve stem on air flow [Re: barryc] #855162
11/16/10 12:54 PM
11/16/10 12:54 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I can tell you that changing from "waisted" 3/8" to "waisted" 11/32" was good for 1-2 cfm (max) on a set of my old heads that were converted to narrower valve stems.
Re: affect of valve stem on air flow [Re: BradH] #855163
11/16/10 01:11 PM
11/16/10 01:11 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
valve itself should be lighter
Re: affect of valve stem on air flow [Re: ademon] #855164
11/16/10 03:47 PM
11/16/10 03:47 PM
Az
Crizila Offline
Crizila  Offline
Az
Ya, I think the big gain is weight reduction for a more stable valve train operation at high rpm"s.
Fastest 300
