HELP !!!!!!! 69 coronet brake question ????? #85510
07/07/08 08:45 PM
07/07/08 08:45 PM
Anonymous OP
Anonymous OP
I have a 1969 Coronet. It has Bendix 4 piston disc brakes. The old calipers are shot and so I changed to the new style. Can I use the portioning valve from the 4 piston brakes? One more thing, I switched from power to manual master cylinder due to low vaccum problems. I have already made the change but my brakes are not as good as I feel they should be with all the changes. I have tried bleeding the brakes but the brake peddle still seems very spongy even after I installed a 10 psi residual valve. Any help would be great.
Re: HELP !!!!!!! 69 coronet brake question ????? #85511
07/07/08 09:30 PM
07/07/08 09:30 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I would think the same prop valve could be used. On the manual MC swap, you may need to try a different size on your rear cylinders.
It's Swifty! Swifty, you toad sucker!
Re: HELP !!!!!!! 69 coronet brake question ????? #85512
07/08/08 05:00 PM
07/08/08 05:00 PM
Anonymous OP
Anonymous OP
Thanks for the advice. More wecome !
Re: HELP !!!!!!! 69 coronet brake question ????? #85513
07/08/08 05:49 PM
07/08/08 05:49 PM
Wayne, Michigan USA
K
KryslerKid Offline
KryslerKid  Offline
K
Wayne, Michigan USA
My B-Body had the same 4 piston setup. I updated the spindles, rotors, calipers, and kept the original proportioning valve, master cylinder and power brake booster. My brakes stop my 6 pack just fine. I didn't think I'd have adequate vacuum with my high compression motor, but it seems real good. I think I'm using 10.78 inch rotors and premium semi-metallic pads, and with just a single piston Cuda/Challenger caliper. Hope this helps...
KK
