mono leaf question/ caltrac
#854981
11/16/10 01:08 AM
11/16/10 01:08 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
what needs to change here, this is how the rear segment rides, its on the frame rails, i think its time to address this, best 60 1.44 rear is real stiff
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: mono leaf question/ caltrac
[Re: Stroker Scamp]
#854983
11/16/10 02:15 AM
11/16/10 02:15 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I know guys will section the frame so the bottom part sits in the sectioned area of the frame.
The also move the top part higher up in the frame to lower the back of the car. I would look at the front suspension first. It needs to be extremely loose up and down, and smooth all the way to top. I use RMS upper A arms, and front struts, double nutted my bottom shock mount and loosened my Koni front shocks to get the car to "drive" under the frontend and "lift" the front with no effort sending all the weight to the rear tires. Once you do this, then you should be able to leave at a higher rpm bettering your 60ft. If more rpm does not help, I would look at your converter. You want the rear to be stiff and do everything you can to encourage the the rear suspension to seperate the body from the tires. Brian
Brian Hafliger
[Re: demon440]
#854985
11/16/10 02:21 PM
11/16/10 02:21 PM
Posts: 4,573 Motor City
6PKRTSE
Motor City
What body style are these on? I am assuming yours is an A-Body. I have this set up on my E-Body & it is not that close to the frame rail. Mine has over an inch or so.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#854987
11/16/10 02:37 PM
11/16/10 02:37 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
You need longer shackles and/or move the frame mounting point. I had to make slightly longer shackles for my Duster with monoleafs. I just bought some of those rear lift shackles (I know, I know) and cut them down so I had clearance between the spring eye and the frame rail. I talked to Calvert about this and they weren't sure why some of them hit and others didn't, I told him because the ones that hit the frame rail have had the springs moved inboard to the frame rail.
[Re: Stanton]
#854990
11/16/10 02:47 PM
11/16/10 02:47 PM
Guitar Jones
It also depends on the arch, I got my mono's -4" arch so they were virtually flat. That lengthens the spring.
[Re: Stroker Scamp]
#854993
11/16/10 11:03 PM
11/16/10 11:03 PM
Posts: 149 OH, USA
Torred
OH, USA
Mine are touching the frame. They told me to take the Monos apart and drill new holes in the rear segment and reassemble so that they would be 1" shorter. Havn't done it yet.
[Re: Stroker Scamp]
#854994
11/17/10 12:00 AM
11/17/10 12:00 AM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Have you talked to Calvert about it? Bill
[Re: 72chrgrally]
#854997
11/17/10 07:23 AM
11/17/10 07:23 AM
KOS
Put a pair of sliders in it. Steve
[Re: KOS]
#854998
11/17/10 10:39 AM
11/17/10 10:39 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
It looks like he has the springs moved in under the frame rail. This problem is not uncommon. I have had to knotch the frame on a and b body cars to get them to fit right. It is not just a mono leaf problem. When the car is down on the springs the rear shacle should be laying back like it is. When the body seperates as that shackle goes threw its arch it is actually planting the tire better.
JAKES AUTOMOTIVE
[Re: JAKE68]
#854999
11/18/10 01:12 AM
11/18/10 01:12 AM
Stroker Scamp
pacific northwest
front end has plenty of travel, rear end is moved back 1" so I think thats where the interference starts thanks for th suggestions, Mike
[Re: JAKE68]
#855000
11/18/10 02:14 AM
11/18/10 02:14 AM
Posts: 1,414 Stow ,Ohio
demon440
Stow ,Ohio
My springs are moved in also, so are most of the people's on this site. I didn't have to notch my frame and neither should you. Take the car to a shop that know's what they are doing next time.
