What gear set for a Dana ? #854677
11/15/10 06:33 PM
11/15/10 06:33 PM
Winnipeg, Canada
StrokerDart Offline OP
Winnipeg, Canada
I'm looking to switch from the 4.56 gears I have in my Moser Dana 60 to a 4.30 ... I think .
It's a street/strip 76 Dart Sport weighing 3200, 455cid small blk, 727 with trans brake, 30" slick and has run a best of 9.76 @ 137 open exhaust ... shift light is at 7200 so shift probably occurs at 7400 and the light is on at the 1000' mark so I'm crossing the stripe at 7400+
Peak HP/TQ throught the mufflers from the chassis Dyno was 585 at 6750 and then drops to 573 and holds there till 7200 (end of run) Peak TQ was 482 at 6350
Am I over geared ??? I'm thinking a 4.30 would bring it down to the 7000 ish mark and I might pick up some et/mph
Any thoughts ?
Re: What gear set for a Dana ? [Re: StrokerDart] #854678
11/15/10 08:40 PM
11/15/10 08:40 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
4.56 is steep for that size engine and 30" tire.
Re: What gear set for a Dana ? [Re: S/ST 3040] #854679
11/15/10 09:09 PM
11/15/10 09:09 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I am running 4.88's but I am running a 32" tire and I am trapping about 74-7500
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: What gear set for a Dana ? [Re: dusturbd340W5] #854680
11/15/10 09:12 PM
11/15/10 09:12 PM
S/ST 3040 Offline
S/ST 3040  Offline
.........and you could use his 4.56
Re: What gear set for a Dana ? [Re: S/ST 3040] #854681
11/15/10 09:16 PM
11/15/10 09:16 PM
Kissimmee Fl.
Kissimmee Fl.
other than a little less trap RPM what else do you think it would change?
Re: What gear set for a Dana ? [Re: dusturbd340W5] #854682
11/15/10 09:21 PM
11/15/10 09:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
Life expectancy and possibly a little ET
Re: What gear set for a Dana ? [Re: S/ST 3040] #854683
11/15/10 09:30 PM
11/15/10 09:30 PM
Kissimmee Fl.
Kissimmee Fl.
well I will just leave it for now we only get to run a few races a year that are 1/4 95% of every thing down here is 1/8 so I don't spin it that high very often.
Re: What gear set for a Dana ? [Re: dusturbd340W5] #854684
11/15/10 09:38 PM
11/15/10 09:38 PM
S/ST 3040 Offline
S/ST 3040  Offline
Years ago, there was a guy back home who had a Dana 60 in his
455/4-speed Trans Am. It had 4.88s (I don't remember tire size).
Anyway, he used to run it at Kanawha Valley (1/8 mile) I told
him it would probably be quicker with 4.10s. He switched to
4.10s and it was quicker. I don't remember how much but, I
know his car was NOT light. True story.
Re: What gear set for a Dana ? [Re: S/ST 3040] #854685
11/15/10 10:18 PM
11/15/10 10:18 PM
Winnipeg, Canada
Winnipeg, Canada
Thanks for the info so far !!
So are we talking 4.30's or ... lower to 4.10's ?
If it's 4.30 ... who makes a good gear ? Richmond does not seem to make them in 4.30 ?
Re: What gear set for a Dana ? [Re: StrokerDart] #854686
11/15/10 10:22 PM
11/15/10 10:22 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Dr. Diff has light weight 4.30's.
Getting old just means you were smarter than some and luckier than others.
Re: What gear set for a Dana ? [Re: StrokerDart] #854687
11/15/10 10:27 PM
11/15/10 10:27 PM
S/ST 3040 Offline
S/ST 3040  Offline
Unless you can get a 32-33" tire under the car, I'd say 4.10
Re: What gear set for a Dana ? [Re: S/ST 3040] #854688
11/16/10 12:09 AM
11/16/10 12:09 AM
Winnipeg, Canada
Winnipeg, Canada
Ok, 4.10 is easier to find so that's good.... Now, should I be looking at a pro-gear ??? It's a street gear in there now and it seems to be doing allright. I do street drive mine "a little" , just cruising to the car show or car wash... but I obviously don't want to break anything !!
Re: What gear set for a Dana ? [Re: StrokerDart] #854689
11/16/10 06:02 AM
11/16/10 06:02 AM
S/ST 3040 Offline
S/ST 3040  Offline
You don't want to run a Pro Gear on the street. The street
gear is harder and work in 98% of drag applications.
Re: What gear set for a Dana ? [Re: S/ST 3040] #854690
11/16/10 08:17 AM
11/16/10 08:17 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
2nd that.
Re: What gear set for a Dana ? [Re: StrokerDart] #854691
11/16/10 09:17 AM
11/16/10 09:17 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Make sure you get the correct series of gear, that 4.56 should be a series 4 and the 4.10 MAY be a series 3. The 4.30 could be either or
Joe
Without Data, you’re just another guy with an opinion.
Re: What gear set for a Dana ? [Re: sr4440] #854692
11/16/10 11:36 AM
11/16/10 11:36 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All pro gears regardless of ratio, all 4.56-7.17 street gears and Richmond 4.10 street gears fit 5 series carriers.
All other 3.54-4.30 street gears fit 3 series carriers.
Re: What gear set for a Dana ? [Re: DoctorDiff] #854693
11/16/10 01:46 PM
11/16/10 01:46 PM
Winnipeg, Canada
Winnipeg, Canada
.... so is there a way of telling what series my Moser Dana 60 is? Or better yet ... Will a Richmond 6900521 4.10 set fit it ??
thanks everyone !!!
Re: What gear set for a Dana ? [Re: StrokerDart] #854694
11/16/10 04:37 PM
11/16/10 04:37 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Once again, all 4.56-7.17 gears fit a 5 series carrier.
Richmond 4.10 street gears also fit a 5 series carrier.
Sounds like you have a 5 series carrier. I doubt Moser used a ring gear spacer and a 3 series carrier to install your 4.56 gears.
Re: What gear set for a Dana ? [Re: DoctorDiff] #854695
11/16/10 06:29 PM
11/16/10 06:29 PM
Winnipeg, Canada
Winnipeg, Canada
THANKS to all !!!!!!!!
Re: What gear set for a Dana ? [Re: S/ST 3040] #854696
11/17/10 03:41 PM
11/17/10 03:41 PM
Roseau, MN
1976 Aspen Offline
1976 Aspen  Offline
Roseau, MN
My car is almost the same deal and I broke my Richmond 4.56's the last race of the season after one full season on them. So does my car fall into the 2% category??? Not likely. I'm switching to Pro Gears and not looking back. By the way, Pro Gears are softer not harder. Hard=brittle, soft= malleable...
