Page 3 of 3 1 2 3
Re: Indy 440-1 users come on in! [Re: cudabin] #854662
12/11/10 10:13 AM
12/11/10 10:13 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Hey Sledgie,
Before my new Indy motor threw 2 rods out the block destroying the complete shortblock, it ran 8.97 at 149.9mph in a 2,850# Cuda.
It made 895HP on the dyno at 6,900 rpm.
Combo:
Indy max low deck Aluminum block. 540ci w/ 4.5 bore and 4.25" stroke. K-1 Crank, R&R 6.635" billet Alum rods w/ 2.20 rod journals.
Custom Ross domed 15:1 compression pistons w/ 1.205" comp height. Charlies Alum oil pan w/ milodon dual line swinging pick up and Melling HV pump.
Top end:
2100cfm Ron's Terminator Alcohol Injection on a low deck Indy manifold, 440-1 Alum heads 345cc intake volume CNC ported by MCH, 382 cfm @ .800"
Custom comp roller 286/294 dur @ .050", .782"/.765" lift, 111 lsa installed at 107 icl.
Headers: TTi 2" - 2 1/8" in chassis step headers, w/ Star Vacuum pump
I'll bet you cried yourself to sleep that night.
Re: Indy 440-1 users come on in! [Re: Dabee] #854663
12/12/10 11:51 AM
12/12/10 11:51 AM
UK
602heavy Offline
602heavy  Offline
UK
Here is mine.
CNC ported heads
jesel rockers and belt drive
1.7 rockers
12.5 comp
496 ci
bill miller pistons
eagle crank, Alum rods
Engine is in a 225 RED
Dyno
817 hp @ 7200 RPM
660 TQ @ 5500
Cam card is suggesting to install on a 108 lobe centre although valve events suggest 4 degree retarded , ....last straightline performance cam i used stated installed valve events , seems those numbers are 4 degrees retarded.
Re: Indy 440-1 users come on in! [Re: moparniac] #854664
12/12/10 05:01 PM
12/12/10 05:01 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What was your final decision re: cam choice?
its a comp cam!
I meant the specs, not the brand.
Re: Indy 440-1 users come on in! [Re: BradH] #854665
12/18/10 02:16 PM
12/18/10 02:16 PM
U.S.
moparniac Offline OP
U.S.
its a comp cam!
Mopar Performance
Page 3 of 3 1 2 3
