Re: Indy 440-1 users come on in!
[Re: cudabin]
#854662
12/11/10 10:13 AM
12/11/10 10:13 AM
Posts: 976 ontario canada
mac56
ontario canada
Hey Sledgie,
Before my new Indy motor threw 2 rods out the block destroying the complete shortblock, it ran 8.97 at 149.9mph in a 2,850# Cuda.
It made 895HP on the dyno at 6,900 rpm.
Combo:
Indy max low deck Aluminum block. 540ci w/ 4.5 bore and 4.25" stroke. K-1 Crank, R&R 6.635" billet Alum rods w/ 2.20 rod journals. Custom Ross domed 15:1 compression pistons w/ 1.205" comp height. Charlies Alum oil pan w/ milodon dual line swinging pick up and Melling HV pump.
Top end:
2100cfm Ron's Terminator Alcohol Injection on a low deck Indy manifold, 440-1 Alum heads 345cc intake volume CNC ported by MCH, 382 cfm @ .800" Custom comp roller 286/294 dur @ .050", .782"/.765" lift, 111 lsa installed at 107 icl.
Headers: TTi 2" - 2 1/8" in chassis step headers, w/ Star Vacuum pump
I'll bet you cried yourself to sleep that night.
[Re: Dabee]
#854663
12/12/10 11:51 AM
12/12/10 11:51 AM
Posts: 1,200 UK
602heavy
UK
Here is mine.
CNC ported heads jesel rockers and belt drive 1.7 rockers 12.5 comp 496 ci bill miller pistons eagle crank, Alum rods
Engine is in a 225 RED
Dyno 817 hp @ 7200 RPM 660 TQ @ 5500
Cam card is suggesting to install on a 108 lobe centre although valve events suggest 4 degree retarded , ....last straightline performance cam i used stated installed valve events , seems those numbers are 4 degrees retarded.
[Re: moparniac]
#854664
12/12/10 05:01 PM
12/12/10 05:01 PM
BradH
What was your final decision re: cam choice?
its a comp cam!
I meant the specs, not the brand.
