Dart doors #85449
07/07/08 08:16 PM
07/07/08 08:16 PM
pa
73roadbird Offline OP
pa
Can someone here tell me if 73 swinger doors will fit a 75 dart sport and if so will the glass interchange as well? I have to real good 73 swinger doors that are almost perfect to replace 2 crappy doors on the sport. The doors themselves look the same but the glass if different. Switching the internal parts won't be a problem if needed, Thanks...
Re: Dart doors [Re: 73roadbird] #85450
07/07/08 08:19 PM
07/07/08 08:19 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There's no way the glass will work from swinger to dart sport, the doors I don't know.
Re: Dart doors [Re: buildanother] #85451
07/07/08 08:22 PM
07/07/08 08:22 PM
pa
pa
I figured the doors would swap out ok, but wasn't sure if the glass from the sport doors would fit into the swinger doors. Going to carlisle and I was hoping that the swinger doors would work than all I would have to do is swap the regulators and glass.
Re: Dart doors [Re: 73roadbird] #85452
07/07/08 08:33 PM
07/07/08 08:33 PM
chicagoland,usa
chicagoland,usa
There's gotta be somebody here that has done it...or tried to do it.
Re: Dart doors [Re: 73roadbird] #85453
07/07/08 08:35 PM
07/07/08 08:35 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
I believe the doors will swap, but the glass will not!
Re: Dart doors [Re: DartGTDan] #85454
07/07/08 09:05 PM
07/07/08 09:05 PM
pa
pa
Just came in from the shop and the swinger door does fit, but the glass is definitely different. I hate to remove the glass from both doors only to find out the sport glass won't fit into the swinger door. I guess I may wait until carlisle and maybe pick up a L/S door. It's a shme Iv'e had these swinger doors for quite a while and they are real nice except for the door panels, but I guess I'll keep them and store them, maybe I will need them for another project.
Re: Dart doors [Re: 73roadbird] #85455
07/07/08 09:12 PM
07/07/08 09:12 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Doors will physically bolt on.
Glass is a no go, need the 2 dr fastback glass.
Re: Dart doors [Re: RobX4406] #85456
07/08/08 07:18 AM
07/08/08 07:18 AM
pa
pa
Ok. if the doors physicaly fit will the glass from the sport fit into the swinger door?
Re: Dart doors [Re: 73roadbird] #85457
07/08/08 09:13 AM
07/08/08 09:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes , its the same door , the shape of the glass is just different , but its the same where it connects to the regulator
Re: Dart doors [Re: JohnRR] #85458
07/08/08 10:11 PM
07/08/08 10:11 PM
pa
pa
Johnrr, Thanks I was hoping that the doors would work, as I mentioned the doors fit, but wasn't sure if the glass would swap out, thanks...
