Page 11 of 16 1 2 9 10 11 12 13 15 16
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853956
08/25/12 01:10 AM
08/25/12 01:10 AM
MO
cdp Offline
cdp  Offline
MO
why not share some more pics of the black 340 4spd.
Re: Young Gun 1971 Roadrunner FAST 340 [Re: cdp] #853957
08/27/12 12:17 PM
08/27/12 12:17 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
are you talking about the dart listed in my sig?
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853958
09/24/12 03:17 PM
09/24/12 03:17 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
after fighting with our laptop for a long while trying to get it fixed, we are going laptop shopping this weekend. ill be uploading pictures then and I have a TON of updates. if all goes well, the car should be road worthy in a few weeks...
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: cdp] #853959
11/04/12 06:49 PM
11/04/12 06:49 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
finally get some pictures up. a lot of summarizing will be done. I have a lot of more progress made after these also. car is almost done. here is the motor about ready for the dyno. as said before, its best pull made 512 hp and 540 ft lbs torque
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853960
11/04/12 06:57 PM
11/04/12 06:57 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
904 trans getting a little work. went with a low gear set, cheetah auto/ manual valve body, semi rigid bands, deep pan, and dynamic converter
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853961
11/04/12 07:00 PM
11/04/12 07:00 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
engine painted with correct hemi orange paint from frank baddleson. tried to paint it sloppy as the factory would do (intensionally thin in areas)
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853962
11/04/12 07:04 PM
11/04/12 07:04 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
thermoquad built by Scott Smith and then I sent it to Jeff Patterson for some slight modification
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853963
11/04/12 07:05 PM
11/04/12 07:05 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
TTI exhaust bought with dynomax ultraflows
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853964
11/04/12 07:08 PM
11/04/12 07:08 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
engine bolted to the tranny bolted to the k frame along with some other accessories. almost ready to bolt into the car
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853965
11/04/12 07:10 PM
11/04/12 07:10 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
last engine bay shot before motor is in
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853966
11/04/12 07:12 PM
11/04/12 07:12 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
car backed out and washed also. tail lights are from BE+A
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853967
11/04/12 07:13 PM
11/04/12 07:13 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
engine in car!
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853968
11/04/12 07:15 PM
11/04/12 07:15 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
radiator from Glen Ray. did a fantastic job!
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853969
11/04/12 07:18 PM
11/04/12 07:18 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I need to take way more pictures as the car is almost done. but this is the last one for now with the steering column installed. all I have left is a few pieces of trim, adjust the side glass, carpet, seats, door panels and figure out a few electrical bugs!
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853970
11/04/12 07:43 PM
11/04/12 07:43 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Looking good !
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853971
11/04/12 09:28 PM
11/04/12 09:28 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I just went out and snapped a few pictures tonight. Ill have to back the car out of the shop to get a decent pictures later on. the reflective 340 decals on the hood are really hard to make out..
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853972
11/04/12 09:29 PM
11/04/12 09:29 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
rear..
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853973
11/04/12 09:31 PM
11/04/12 09:31 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
trunk compartment..
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853974
11/04/12 09:33 PM
11/04/12 09:33 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
nearly complete engine compartment. its my winter project to restore my a/c. latches were restored by Jules Daddio
1937 Plymouth PT50
Re: Young Gun 1971 Roadrunner FAST 340 [Re: mopars_1] #853975
11/04/12 09:37 PM
11/04/12 09:37 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
close up on the drivers carb. also showing my dr1114429 solenoid! restored by Scott Smith. extra wiring on the coil is the Pertronix ignitor 3. the rev-limiter works very well.
1937 Plymouth PT50
