Need timing info 1973 318 manual trans-UPDATE
#853731
11/15/10 12:59 AM
11/15/10 12:59 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
I have been doing some maitenance on my 73 Satellite wagon. My FSM does not show the intitial timing. It says "refer to vehicle emissions placard under the hood' Well the placard is long gone. I checked the timing and it is set at ZERO. I need to know what it should be set at. It is a stock 318 with 3 speed manual trans. I will be replacing the worn out original 2bbl carb,and I already installed dual exhaust. Any info is greatly appreciated.
Re: Need timing info 1973 318 manual trans
[Re: RapidRobert]
#853742
11/15/10 09:38 PM
11/15/10 09:38 PM
68Cbarge
Canuckville
Thanks guys! My last 318 car did work best at 12 degrees in my 87 Diplomat.I was not sure of there were any differences compared to my 73. A recurve is in the works later on.I did recurves in the past with positive results. For now,I am working with what I got. I run 91 octane always.I get better MPG and go longer in between fill ups. I did put in 87 octane once when there was nothing else available and she deiseled and smoked---not liking it at all.Never again. I am averaging 21 MPG with the goal of getting 24 on the highway. A recurve,new carb,and some fine tuning will help meet my goal. Thanks again.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 68Cbarge]
#853744
11/15/10 09:48 PM
11/15/10 09:48 PM
RapidRobert
At TDC plus (probably) a slow curve I'm surprised it's not running hot and no power
[Re: 68Cbarge]
#853747
11/16/10 12:33 AM
11/16/10 12:33 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
...She is a cold blooded 318,though.Will not drive unless fully warmed up--or stall city. ...
It might be time to pull the intake manifold and clean out the exhaust crossover passage. With a cold engine, start it up and feel how fast the area of the choke coil warms up.
[Re: Moparzrule]
#853749
11/19/10 12:20 AM
11/19/10 12:20 AM
68Cbarge
Canuckville
Filled her up today.I was still running on the tank I filled in Toronto Saturday!! She was thirsty,though.70.00 worth of 91 octane 63.03 litres or 16.65 gallons With the fresh gas in her belly,I wanted to check the timing. The trip to Toronto she started to deisel and was running hot,and took a bit of effort to get up to speed. Timing was found at TDC or zero.vacuum was low and could come up a bit. basically,timing was retarded. I cranked her up at 7 degrees BTC.Vacuum jumped to a rock steady 20 inches on the nose. I dropped the idle down to normal and the vacuum stayed at 20. She now very responsive.I took her for a drive and made sure she did not ping...no ping under a load up a hill.no need to downshift...lots of torque,no clutch slip..That's good. No flat spot...even much better. I have not yet dumped the clutch and lay rubber. The condition of the clutch is unknown and I am not about to find out. Maybe 10 degrees would be better? Being a standard trans,not much more may be?? First, I will try this for a day or two and see. Plugs are tan in color with some light deposits,(running a tad lean ,sign of getting hot.) Plug Gap at 35 thou. Waygun purrs now..You can put a sleeping baby on the air cleaner and not wake up.
[Re: stumpy]
#853751
11/19/10 01:09 AM
11/19/10 01:09 AM
68Cbarge
Canuckville
Thanks. My friend who owns a 73 D100 has a underhood placard and it shows timing should be set at zero--where it was before I jacked it up. I will be driving to Watertown,NY this Sunday and will top up the tank and calculate my MPG and see if the bump has helped or hindered my MPG.
