Re: MSD Problems
[Re: kzinge1]
#853452
11/14/10 04:09 PM
11/14/10 04:09 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Well they do not like heat, that being said mounted in the engine compartment away from headers should be sufficient. Having said that I have ALWAYS run mine in the interior of the car. Do you have the power and ground wires for the box run directly to the battery? Also what about the coil?
Re: MSD Problems
[Re: kzinge1]
#853454
11/14/10 09:39 PM
11/14/10 09:39 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
Make a little sheet metal baffle to shield it and find out My MSD7C is mounted on the top of the drivers side inner fenderwell right above where the battery would be if I had the battery in the stock location,my battery is in the trunk. I run a set of two inch Hooker fenderwell headers in my Duster, there 4 or 5 inches away from the MSD box My MSD coil is mounted on the front of the motor on the front of the intake valley shield right behind the thermostat housing. I drive it on the street in 90F weather here in central oregon and it has never missed a beat, not once in four years now
Re: MSD Problems
[Re: Big Squeeze]
#853463
11/18/10 01:21 PM
11/18/10 01:21 PM
Quicktree
I would never mount any ingnition box under the hood
I bet I've mounted at least 50 under battery trays and have never had an issue.......I did two just last week........
yea and 999 out of a 1000 people who jump out of planes have no problems. wonder what that 1 thought?
Re: MSD Problems
[Re: idriveagremlin]
#853465
11/18/10 01:31 PM
11/18/10 01:31 PM
Quicktree
MSD= M.y S.park D.isappeared!
guess I have been real lucky, over 30 years of racing using MSD products and not 1 failure
Re: MSD Problems
[Re: 77DragracerR/T]
#853467
11/18/10 03:18 PM
11/18/10 03:18 PM
Posts: 2,648 GA
Boosted
GA
I cannot help with your problem but I can say that I do run my box's under the hood on the frewall. Never a problem with this..
I did have to send one box back this year and it was because I bought it off a flooded car.. got wet and was done. MSD was very quick and fixed this box for me.. No issues with it now and I have it on my 512... Ran it during the break in period and worked perfectly...
It is worht getting an RMA and sending them back... They will fix them.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
