What driveshaft are you using? Need suggestions
#853201
11/14/10 01:33 AM
11/14/10 01:33 AM
Posts: 513 HOUSTON,TEXAS
FIREGUY12
HOUSTON,TEXAS
Ok im down to buying a driveshaft for my car. Just wanted to know what material some of you are using. I have a 600h.p,650 torque engine with a powerglide 1.80. Car weight just guessing 3000lbs. The engine won't see over 7200 rpm.
Will a steel driveshaft .095 wall suffice. 1350 U Joints. Driveshaft will be around 53-56 inches.
Re: What driveshaft are you using? Need suggestions
[Re: FIREGUY12]
#853202
11/14/10 12:30 PM
11/14/10 12:30 PM
Posts: 1,559 Michigan
Kiddart
I used Mr. P Body's advise and called DYNOTECH in the dtroit metro area. I got the 3.5 inch DOM good for up to 1000hp, large joints for well under 500 bucks www.Dynotech.comor www.PST.com(way more expensive)
Thank you Kiddart
[Re: FIREGUY12]
#853206
11/14/10 04:35 PM
11/14/10 04:35 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Another happy Dynotech customer here as well. FWIW I have a mild steel 1350 jointed shaft in the Cuda. Been there for a few years and no issues. Off the stop 1.teen 60's and bottom 8's at 2900lbs.
[Re: joshking440]
#853210
11/14/10 08:01 PM
11/14/10 08:01 PM
Posts: 2,792 IN
Dartman928
IN
I have a dynatech 3" chrome moly
I second was Josh says ![](/ubbthreads/images/graemlins/biggrin.gif)
Dynatech one of the best out there ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: justinp61]
#853215
11/15/10 09:17 PM
11/15/10 09:17 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Dynotech here too, great customer service .
Dynotech 3 1/2" .125" wall aluminum, 1350 joints w/Mark Williams 904 yoke.
Driveshaft speed of 8000+
1-800-633-5559 FREE SHIPPING
[Re: S/ST 3040]
#853216
11/15/10 11:05 PM
11/15/10 11:05 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
I have a MWE CM shaft and yokes. No problems.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: S/ST 3040]
#853217
11/15/10 11:07 PM
11/15/10 11:07 PM
Quicktree
Dynotech 3 1/2" .125" wall aluminum, 1350 joints ![](/ubbthreads/images/graemlins/thumbs.gif)
same here ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 70RTRacer]
#853218
11/15/10 11:11 PM
11/15/10 11:11 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
I have a Mark Williams CM shaft and yokes. No problems.
Ditto ![](/ubbthreads/images/graemlins/thumbs.gif)
