What driveshaft are you using? Need suggestions #853201
11/14/10 01:33 AM
11/14/10 01:33 AM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Ok im down to buying a driveshaft for my car. Just wanted to know what material some of you are using. I have a 600h.p,650 torque engine with a powerglide 1.80. Car weight just guessing 3000lbs.
The engine won't see over 7200 rpm.
Will a steel driveshaft .095 wall suffice. 1350 U Joints. Driveshaft will be around 53-56 inches.
Re: What driveshaft are you using? Need suggestions [Re: FIREGUY12] #853202
11/14/10 12:30 PM
11/14/10 12:30 PM
K
Kiddart Offline
Kiddart  Offline
K
I used Mr. P Body's advise and called DYNOTECH in the dtroit metro area. I got the 3.5 inch DOM good for up to 1000hp, large joints for well under 500 bucks
www.Dynotech.com
or
www.PST.com(way more expensive)
Thank you
Kiddart
Re: What driveshaft are you using? Need suggestions [Re: FIREGUY12] #853203
11/14/10 02:14 PM
11/14/10 02:14 PM
Yes My Duster has one of the old Mopar driveshaft kits in it, .083 wall 3.25 diameter that originally had 7260 rear yoke and U joints, 7290 front U joint with a stock traany yoke. I broke the front tranny yoke, I also spread a new Dana Corp 7260 forged pinion yoke apart far enough to let the interior U joint keepers slide out( I replace that yoke with a forged steel 7260 unit And finally ripped the ladder bar brackets off of the 8 3/4 housing, the housing( no back brace ) was bent horribly from the abuse of a 3450 lb car running low to mid tens I now have a Dana 60 (truck housing with 3 .125 axle tubeswelded all thw way around the center section )in the car with the same 7290 front yoke and U joint and a 1330 rear yoke and u joint All with the same driveshaft This is a street and strip car that made 612 HP and 644 Ft. Lbs torque when I first built he motor, now has 718 HP and 740+ Ft. Lbs. 1.43 60 ft. best on ET Street Radials and ladder bars IHTH
Re: What driveshaft are you using? Need suggestions [Re: Cab_Burge] #853204
11/14/10 02:32 PM
11/14/10 02:32 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I have a dynatech 3" chrome moly
Re: What driveshaft are you using? Need suggestions [Re: joshking440] #853205
11/14/10 04:19 PM
11/14/10 04:19 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
So at what point does a steel shaft vs chrome moly become unsafe. I think I will be ok with a steel driveshaft. I just want to be safe. Thanks moparts.
Re: What driveshaft are you using? Need suggestions [Re: FIREGUY12] #853206
11/14/10 04:35 PM
11/14/10 04:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Another happy Dynotech customer here as well. FWIW I have a mild steel 1350 jointed shaft in the Cuda. Been there for a few years and no issues. Off the stop 1.teen 60's and bottom 8's at 2900lbs.
Re: What driveshaft are you using? Need suggestions [Re: Al_Alguire] #853207
11/14/10 04:44 PM
11/14/10 04:44 PM
O'Fallon,IL.
70RTRacer Offline
70RTRacer  Offline
O'Fallon,IL.
I have a Mark Williams CM shaft and yokes. No problems.
Re: What driveshaft are you using? Need suggestions [Re: FIREGUY12] #853208
11/14/10 05:23 PM
11/14/10 05:23 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Strange Engineering has the best deal on cr-mo shafts.
Re: What driveshaft are you using? Need suggestions [Re: 70RTRacer] #853209
11/14/10 06:42 PM
11/14/10 06:42 PM
QLD Australia
Keith Black® Offline
QLD Australia
Mark Williams
http://www.markwilliams.com/default.aspx
Darren Beale
Keith Black Racing Engines®
Re: What driveshaft are you using? Need suggestions [Re: joshking440] #853210
11/14/10 08:01 PM
11/14/10 08:01 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
I second was Josh says
Dynatech one of the best out there
Re: What driveshaft are you using? Need suggestions [Re: FIREGUY12] #853211
11/14/10 08:56 PM
11/14/10 08:56 PM
If your looking for the absolute last bit of performance gain for your car AND expenses are not a CONCERN,then look at buying a carbon fibre matrix shaft or a little cheaper aluminum shaft. Epecaiily at that length The choice is yours I used the mopar drive shaft kit because I had two of them(free to me )and I was trying to build a fast street car with cost part of the decision making process. My new race car will have either a alunimun or chrome moly shaft, whichever is the best, strongest and lightest for that application with no price concerns, weight being the final decider
Re: What driveshaft are you using? Need suggestions [Re: Cab_Burge] #853212
11/14/10 10:22 PM
11/14/10 10:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dynotech here too, great customer service .
Re: What driveshaft are you using? Need suggestions [Re: Cab_Burge] #853213
11/14/10 10:35 PM
11/14/10 10:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
, and when a CF self destructs, there is a lot less damage likely.
However if cost is a concern, I use and like a MW glued alum 1350 3.5" driveshaft.
Re: What driveshaft are you using? Need suggestions [Re: jcc] #853214
11/15/10 09:13 PM
11/15/10 09:13 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
STRANGE HERE, 3 1/2" CHROMEMOLY 1350 U-JOINTS CHROMEMOLY SLIP YOKE. WORKS FINE
Re: What driveshaft are you using? Need suggestions [Re: justinp61] #853215
11/15/10 09:17 PM
11/15/10 09:17 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Dynotech 3 1/2" .125" wall aluminum, 1350 joints w/Mark Williams 904 yoke.
Driveshaft speed of 8000+
1-800-633-5559 FREE SHIPPING
Re: What driveshaft are you using? Need suggestions [Re: S/ST 3040] #853216
11/15/10 11:05 PM
11/15/10 11:05 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
I have a MWE CM shaft and yokes. No problems.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: What driveshaft are you using? Need suggestions [Re: S/ST 3040] #853217
11/15/10 11:07 PM
11/15/10 11:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
same here
Re: What driveshaft are you using? Need suggestions [Re: 70RTRacer] #853218
11/15/10 11:11 PM
11/15/10 11:11 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Ditto
Re: What driveshaft are you using? Need suggestions [Re: CRE2004] #853219
11/15/10 11:18 PM
11/15/10 11:18 PM
Texas, USA
68cuda2003 Offline
68cuda2003  Offline
Texas, USA
just got a strange engineering chrome moly shaft with chrome moly ends and 1350 ends for $319. very nice piece at an excellent price. trust me, I did the shopping and apples to apples, this was the best deal.
