Harland Sharps or Comp. #853176
11/14/10 12:03 AM
11/14/10 12:03 AM
Roseville MN
72swgnr Offline OP
72swgnr  Offline OP
Roseville MN
Just curious what roller rockers you guys would use for a mostly street driven small block. The springs I'm using with my build are around 400lbs. Open. Harlands are aluminum and the comps I'm looking at are steel. Do the Harlands hold up to street miles or are they more of a race only piece?
Any one have any real world experience with their own engines? Thanks!
Re: Harland Sharps or Comp. [Re: 72swgnr] #853177
11/14/10 12:33 AM
11/14/10 12:33 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Harland Sharp!!!!
Re: Harland Sharps or Comp. [Re: 72swgnr] #853178
11/14/10 12:44 AM
11/14/10 12:44 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Just had a comp seize on to the shaft, bent the push rod, popped the lifter, lost oil pressure, probly more damage.
That being said, I previously ran a set of comp for about 30000 miles and about 1000 passes w/no problem. Thought it was time to replace them. Sometimes should leave well enough alone!
Will probably have the comps bushed and use them again
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Harland Sharps or Comp. [Re: 72swgnr] #853179
11/14/10 01:25 AM
11/14/10 01:25 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Harland sharps
Re: Harland Sharps or Comp. [Re: Twin Turbo Mower] #853180
11/14/10 01:58 AM
11/14/10 01:58 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sharps.
Re: Harland Sharps or Comp. [Re: 72swgnr] #853181
11/14/10 02:34 AM
11/14/10 02:34 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
IMO 400# open is on the bubble for comps. Comp says they're good to 500#, but I kind of doubt it.
I use comps in my motor, but I'm only running 350# open.
Re: Harland Sharps or Comp. [Re: 72swgnr] #853182
11/14/10 11:13 AM
11/14/10 11:13 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have bronze bushed Comps. +500 open. Lots of street miles. I like the way they oil everything. I would do it again. However, including bushing, they were more expensive than the HS.
Re: Harland Sharps or Comp. [Re: 72swgnr] #853183
11/14/10 11:55 AM
11/14/10 11:55 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I thought Comp started bushing them?
Mine are older, unbushed Comps. OVER 500 lbs. open pressure.
No galling, siezed rockers, etc. My only other complaint is their
lack of optional ratios.
Re: Harland Sharps or Comp. [Re: 72swgnr] #853184
11/14/10 11:58 AM
11/14/10 11:58 AM
S/ST 3040 Offline
S/ST 3040  Offline
Re: Harland Sharps or Comp. [Re: S/ST 3040] #853185
11/14/10 02:25 PM
11/14/10 02:25 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Mine aren't bushed, that's for sure...
