What is this called or do #852613
11/13/10 04:46 PM
11/13/10 04:46 PM
Texas
70Runnerdude Offline OP
Texas
It either came out of a 70 Challenger or a 70 GTX for the radio. Not sure what it is called or what it does.
David
Re: What is this called or do [Re: 70Runnerdude] #852614
11/13/10 05:00 PM
11/13/10 05:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
looks like the speaker crossover for an AM 8 track,,,,not sure if it's also used on AM/FM's as well or not
Re: What is this called or do [Re: gtx6970] #852615
11/13/10 08:03 PM
11/13/10 08:03 PM
Alabama
BigMoneyLewis Offline
Alabama
Stereo crossover box , and since you took it out of a B body , it was from an AM 8-track car.
(1970 B body AM FM radios were mono )
All AM 8track B bodies had 3 speaker dashes . The AM stereo 8 track radio produces 2 channels . By going through this box, it then creates the 3rd channel . Lower base sounds are directed to the center speaker, and the higher sounds to the two outboard speakers.
You will also find a special 3 speaker harness under the dash as well.
Greg
gregward@mchsi.com phone 256-852-0955
