Re: 1.88 Int. valve H.P potential???
[Re: S/ST 3040]
#852462
11/13/10 04:46 PM
11/13/10 04:46 PM
Posts: 214 canada,NB
jb15
canada,NB
thanks Guys, and thanks for the porting picture, was hoping to get around 375 to 400hp, with stock pistons,car is streetable,also going to be a very cheep build,I have a old holley strip dominator intake and 750cfm holley to throw at it along with head work,right hdr.cam, we'll see.. Jim..
[Re: mshred]
#852466
11/13/10 08:00 PM
11/13/10 08:00 PM
Posts: 5,895 Florida
Locomotion
This is great info! i was wondering how much potential my 308 castings would have with home porting and the stock 1.88" intake valve. Id like to a hit a 11 in my 360 powered 3400lb car
It shouldn't be a problem, but it's not just the heads. It's the whole car combo. I've been 11.31 with unported OEM heads at 3,540+ lbs under IHRA Stock crate motor rules. S/ST's heads are, I bet, are on a Super Stock combo. Other 1.88 360 Stock classed cars in NHRA and IHRA have been in the high 10's with 1.88" valves.
[Re: jb15]
#852467
11/13/10 08:36 PM
11/13/10 08:36 PM
Posts: 7,506 Az
Crizila
Az
375hp - maybe on the very high end with some major block / head work ( it won't be a cheap build)to address the stock piston low comp. issue. Mid to low 12's if ALL ELSE is matched correctly ( also won't be a streetable gear )and the car is a fly weight. 10,s = fantasy land!
Fastest 300
[Re: MoparforLife]
#852470
11/13/10 09:59 PM
11/13/10 09:59 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
i would say stay with the 1.88 if on a budget and looking for a 375hp motor, but on my 360 i went with the 2.02, i'm putting out about 400 to 420hp i think the Chrysler engineers knew what they were doing when they had the 2.02 valves in the hot 68-71 340's. those stock NHRA cars are running wild gears, big $$$ trans, Besides the F.A.S.T 340 cars are using 2.05 in there J's to get the flow and they are making 500hp with stock intake and exhaust manifolds
