Super Stock Dart wheels #852169
11/12/10 08:37 PM
11/12/10 08:37 PM
Howell, Michigan
Hemidavey Offline OP
Howell, Michigan
what wheel did Chrysler use on the rear of the Hemi Darts in 68. I thought it was steel but they had a Dana 60 from a B Body, did the tires stick out? How wide are the wheels?
Re: Super Stock Dart wheels [Re: Hemidavey] #852170
11/13/10 02:20 AM
11/13/10 02:20 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
basically a "HEMI" 15x6" wheel with special offset - covered HERE!
Re: Super Stock Dart wheels [Re: 6bblgt] #852171
11/13/10 08:31 PM
11/13/10 08:31 PM
Howell, Michigan
Howell, Michigan
Thank you for the help. I'll look for something wider to use that will mount a drag radial. The offset info is very helpfull. This thing should be a blast on the power tour!
