Where to buy glyptal? #852155
11/12/10 08:28 PM
11/12/10 08:28 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Other than mail order is there any place that carries the glyptal paint? I see where it is also used in electrical motors and thought maybe kirby risk.
Re: Where to buy glyptal? [Re: maxie] #852156
11/12/10 08:51 PM
11/12/10 08:51 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: Where to buy glyptal? [Re: HEMIFRED] #852157
11/13/10 06:31 PM
11/13/10 06:31 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mine came from Eastwood.
Re: Where to buy glyptal? [Re: FastmOp] #852158
11/13/10 07:18 PM
11/13/10 07:18 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I buy mine from a local industrial supply warehouse. Probably one similar in your area. This one is not a franchise/chain type deal, just a privately owned company.
If you like drag racing, support your local track.
Re: Where to buy glyptal? [Re: CHAPPER] #852159
11/13/10 08:34 PM
11/13/10 08:34 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I couldnt find it anywhere local so I ordered it from eastwood.
Scott
Re: Where to buy glyptal? [Re: maxie] #852160
11/13/10 09:56 PM
11/13/10 09:56 PM
The Glyptol that Eastwood sells is NOT the G.E brand, there is a world of difference Sorry for not pointing that out sooner
Re: Where to buy glyptal? [Re: Cab_Burge] #852161
11/14/10 12:14 AM
11/14/10 12:14 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Brehob or McBroom or Horner Electric here in Indy, If you need some let me know
Re: Where to buy glyptal? [Re: Cab_Burge] #852162
11/14/10 12:32 AM
11/14/10 12:32 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Is eastwood's better or worse?
Re: Where to buy glyptal? [Re: joshking440] #852163
11/14/10 12:33 AM
11/14/10 12:33 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Thanks. I ordered it from eastwood earlier today and I need to have it by Friday.
Re: Where to buy glyptal? [Re: joshking440] #852164
11/14/10 12:35 AM
11/14/10 12:35 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
You know what's better than painting your lifter valley? Grinding the lifter valley smooth. Yes, it's more work, but you won't have to worry about the stuff flaking off and doing harm to your engine.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Where to buy glyptal? [Re: DusterDave] #852165
11/14/10 11:04 AM
11/14/10 11:04 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have painted mine before. It made it easy to see when cleaning. On the other side look inside of a Barton Hemi. No paint,no grinding in the valley area. If it was really worth it wouldn't he do it? The motors do have the lower block area milled for windage though.
Doug
Re: Where to buy glyptal? [Re: maxie] #852166
11/14/10 02:45 PM
11/14/10 02:45 PM
I'm not sure, I've never used the G.E brand I used the stuff Eastwood sells once, never agian, it would chip off, way to hard I use the red Rustoleum Damp Proof Primer in all of my motors As far as what Barton uses his prices are expensive enough, deburring and painting the insides does not add to the power, just the longivity
Re: Where to buy glyptal? [Re: Cab_Burge] #852167
11/14/10 03:12 PM
11/14/10 03:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Although there are not as many as thier used to be look for a local electric motor company. Anyone who rebuilds electric motor shouddl have it local. Even as pointed out electrical supply houses carry it. BTW I have never seen it flake off if PROPERLY applied also never used anything but the original. I have also used the damp proof rustoleum with no issues.
Re: Where to buy glyptal? [Re: Al_Alguire] #852168
11/14/10 11:57 PM
11/14/10 11:57 PM
Renton Washington
Triple Threat Offline
Renton Washington
Whats the idea here, Just improve oil drain back? I like Daves smoothing idea more. Any thoughts? I'm build a 318
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
