Engine control module #852097
11/12/10 06:42 PM
11/12/10 06:42 PM
georgia
mopa Offline OP
mopa  Offline OP
georgia
I bought a orange box replacement module that has four pins but the one I took off has five pins. What is the difference and will it work on my car?
Re: Engine control module [Re: mopa] #852098
11/12/10 07:39 PM
11/12/10 07:39 PM
yes it'll run but if you have not opened its' pkg or installed it yet I would strongly suggest that you grab the receipt (and it) & refund it & buy a $15 parts house black replacement one (a 5 pinner). More info later. What coil? OE? ohm it if you have a VOM
Re: Engine control module [Re: RapidRobert] #852099
11/12/10 11:10 PM
11/12/10 11:10 PM
georgia
mopa Offline OP
mopa  Offline OP
georgia
The coil is OE and I went to O'reillys and got their in house module. I will take the orange box back to Summit Racing which is not far from me, Thanks.
Re: Engine control module [Re: mopa] #852100
11/12/10 11:35 PM
11/12/10 11:35 PM
Did your box go out or start to miss or are you wanting more perf? If perf I'd start by reworking the advance systems (in order) in the stock dist. A hotter coil & a ballast to match the coil would be the next step. The ECU is pretty much just a switch to control the coil pri circuit though it can only handle (switching on/off) so much current (just like any switch) and the amperage is determined by the coil/ballast combo. New(er) orange boxes have a disproportionate amt of reliability issues (they'll start missing erratically) and have been tested & shown (on occaision) to retard timing at higher rpms which you'd never catch if you weren't looking for that.
Re: Engine control module [Re: RapidRobert] #852101
11/13/10 01:42 AM
11/13/10 01:42 AM
georgia
mopa Offline OP
mopa  Offline OP
georgia
I replaced it because the hard shellac stuff that fills the back side of the module was melting into the engine compartment. Every thing was running fine though.
Re: Engine control module [Re: mopa] #852102
11/13/10 01:53 AM
11/13/10 01:53 AM
Actually they can bleed like a stuck hog & still function but it does look nasty & gives you thoughts of impending doom such as a breakdown on the way to an important event that you cannot miss. Can raise it up off the fender w 2 spacers and or mount it where there is some air flow. EDIT Nacho posted something on why they melt & at 1st thought it was a high charging rate but after thinking, it way have been something else , a circuit not grounded well inside . He'll post if he sees this
