Used cam + new lifters? #85202
07/07/08 12:16 PM
07/07/08 12:16 PM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
Is it OK to use a used cam with new lifters or will the wear pattern on the cam mess up the lifters?
Re: Used cam + new lifters? [Re: whitemtnelf] #85203
07/07/08 12:20 PM
07/07/08 12:20 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Ive done this many times and have had ZERO problems of course results may vary.
Re: Used cam + new lifters? [Re: whitemtnelf] #85204
07/07/08 12:28 PM
07/07/08 12:28 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i've done it also
Re: Used cam + new lifters? [Re: whitemtnelf] #85205
07/07/08 12:36 PM
07/07/08 12:36 PM
Kirkland, Washington
Pacnorthcuda Offline
No problem at all. Just observe the usual cam breakin procedure including the 20 minutes at 2000-2500 rpm, etc.
Re: Used cam + new lifters? [Re: Pacnorthcuda] #85206
07/07/08 12:44 PM
07/07/08 12:44 PM
Iowa
3
318Bruiser Offline
318Bruiser  Offline
Iowa
I was just about to ask this question. Thanks for the info.
Re: Used cam + new lifters? [Re: whitemtnelf] #85207
07/07/08 12:46 PM
07/07/08 12:46 PM
New Hampshire
W
W
New Hampshire
Thanks guys.
Re: Used cam + new lifters? [Re: whitemtnelf] #85208
07/07/08 12:56 PM
07/07/08 12:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
here too!
Re: Used cam + new lifters? [Re: mopars4ever] #85209
07/07/08 01:23 PM
07/07/08 01:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep, not a problem, just the other way around you really don't want to do. IE new cam with used lifters is a bad idea.
