Re: No spark
[Re: stumpy]
#851988
11/13/10 10:13 AM
11/13/10 10:13 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Hook a test light to ground and hold the other end to the neg on coil that goes to the dist.Crank it and it should flash.That tells you everything to the dist and the dist is good.Rocky
Chrysler Firepower
Re: No spark
[Re: way2fast]
#851990
11/13/10 11:13 AM
11/13/10 11:13 AM
RapidRobert
when cranking you have the light at the coil neg pri & it is lit but it is not flashing on/off? (1) ECU lost it's ground (2) ECU bad (3) dist not triggering the ECU (check pickup continuity and disconnected/by itself it should generate iirc ~1volt when cranking (vom on low scale for volts)
Re: No spark
[Re: stumpy]
#852000
11/13/10 10:48 PM
11/13/10 10:48 PM
Posts: 15,487 Florida
scratchnfotraction
if that baby has a keyed hot wire on the + side of coil with key on this is where I drop a points dist with a pertronix points conversion in it,with the 40,000 volt flame thrower coil unplug the ecu,jumper the BR for full 12 volts to conversion and ride sally ride but thats just me,I have not had a late 70s-late 80s mopar that was not done this way just for this reason done changed everthing and still no worky if i low on the cash I just drop in the reman point dist and remove the - side of coil and hook the points wire up and go has always fired up and ran every time after that I AM NOT SAYING....i am just saying... run what ya brung
Re: No spark
[Re: way2fast]
#852002
11/14/10 01:46 AM
11/14/10 01:46 AM
RapidRobert
did that..... no sparky.
do we have fire at the coil primary positive terminal w the key turned to "start".
Re: No spark
[Re: RapidRobert]
#852003
11/14/10 08:27 PM
11/14/10 08:27 PM
Posts: 219 Southwest
way2fast
Southwest
Go Fast and Swerve!
