HEATER CORE REPLACEMENT ON '65 BELVEDERE #851964
11/12/10 04:57 PM
11/12/10 04:57 PM
Rockford, IL
foz Offline OP
International Diplomat
foz  Offline OP
Rockford, IL
How hard is it to change a heater core on a '65 Belvedere?? MY DRIVERS FLOOR IS WET DARNIT!!!!
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: foz] #851965
11/12/10 06:14 PM
11/12/10 06:14 PM
Andrewh Offline
Andrewh  Offline
heat only, or a/c?
I have only pulled the heat only. Pretty small box compared to the 66 and up.
3 bolts on the firewall, and 2 or 3 supports under the dash, plus the fresh air connection.
shouldn't take more than a few hours to pull it out.
then you have to split it open to get the core out.
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: Andrewh] #851966
11/12/10 06:25 PM
11/12/10 06:25 PM
Rockford, IL
foz Offline OP
foz  Offline OP
Rockford, IL
Heat only, I have to pull the whole heater box out huh?
Won't the radio have to come out first or anything else besides the supports?
Also, what about the heater control valve?? Could that be bad as well or maybe the problem?
Thanks very much.
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: foz] #851967
11/12/10 07:05 PM
11/12/10 07:05 PM
Andrewh Offline
Andrewh  Offline
it has been 5 years since I pulled mine, so not sure on some of the details.
my radio was aftermarket.
cables on the box have to be removed for the heater control. Don't recall where teh valve mounts.
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: Andrewh] #851968
11/12/10 08:02 PM
11/12/10 08:02 PM
Rockford, IL
foz Offline OP
foz  Offline OP
Rockford, IL
where the heck can I get a heater core for my '65 Belvedere? The local parts store has no listing(O'Reilly Auto)
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: foz] #851969
11/12/10 11:24 PM
11/12/10 11:24 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
do you have a pic of the heater core? and maybe some rough dimensions.
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: macmic87] #851970
11/13/10 09:59 AM
11/13/10 09:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The seal on the heater valve could be leaking.Yes the whole box has to come out.That and mark the vacuum lines and dont bend the heat cable.I have a complete box in the garage but its been probally 10 years since zi pulled it out of my parts car.The air hoses will probally fall apart if you arent careful.Rocky
Chrysler Firepower
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: therocks] #851971
11/13/10 11:02 AM
11/13/10 11:02 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
You can't buy a new heater core for one of these early B-body cars over the counter. I have a buddy who re-cores with new material for around $200. A radiator shop near you should be able to help. Seen a few cars where using what looked like a good core, ruined brand new carpeting soon after.
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: Bull1tt] #851972
11/13/10 11:10 AM
11/13/10 11:10 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
would that be the same as a Fury for that year?
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: therocks] #851973
11/13/10 01:48 PM
11/13/10 01:48 PM
Rockford, IL
foz Offline OP
foz  Offline OP
Rockford, IL
I really only see antifreeze coming out right at the valve so maybe it's only that.
ALSO, my heater cable needs replacing. Is there new ones available??
Thanks to all for their help!
Any more ideas???????
Foz
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: foz] #851974
11/13/10 04:30 PM
11/13/10 04:30 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Nobody makes a replacement, so you need to have your's rebuilt.
Contact.. http://www.classicheaters.com/
They can rebuild yours, takes about a week, provided they have the core materials in-stock.
Just my $0.02...
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE *DELETED* [Re: foz] #851975
12/12/10 05:24 PM
12/12/10 05:24 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
Post deleted by macmic87
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: macmic87] #851976
12/12/10 05:38 PM
12/12/10 05:38 PM
Batavia,Ohio,
Moparmick Offline
Moparmick  Offline
Batavia,Ohio,
Check with this guy he rebuilds heater valves did one for me on a 65 coronet www.heatervalves.net, His name is Joe Hudacek phone #208-376-7363
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: Moparmick] #851977
12/13/10 08:48 AM
12/13/10 08:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The valve is on the drivers side.Its right near the gas pedal.I have to crawl under the dash to flip mine as my cable went south years ago.The valve is easy to get out once you pull the box.I have my spare one sitting in the garage.Rocky
Chrysler Firepower
Re: HEATER CORE REPLACEMENT ON '65 BELVEDERE [Re: Sinitro] #851978
01/13/11 12:37 AM
01/13/11 12:37 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I was in the same situation with my 57 Belvedere. I took it to a local radiator shop and they recored it.
It's Swifty! Swifty, you toad sucker!
