What do you guys do for those hard to get to areas?? #851906
11/12/10 04:14 PM
11/12/10 04:14 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
What are you guys doing in those hard to get to areas like boxed in sections of framing and sheet metal where you have absoloutely no access other than the 1" diameter drain holes? I've got a lot of boxed in areas where I can see there is a bit of dirt and a small amount of surface rust but I have no way of getting to it without going overboard and drilling out 1,000,000 spot welds needlessly. Like inside solid frame rails. Seems a shame to have the outsides get a nice layer of epoxy primer but not be able to get at the insides. What are you guys doing in these areas? Pressure wash as best I can and live with it? Try and get some phosphoric acid coating in there??
Re: What do you guys do for those hard to get to areas?? [Re: DaytonaTurbo] #851907
11/13/10 01:01 AM
11/13/10 01:01 AM
Oakbank, MB Canada
mbmopar Offline
mbmopar  Offline
Oakbank, MB Canada
I used a long piece of old trans cooler line, attached it to my blow gun via a rubber hose, and about 40 psi I cleaned out approx 20 lbs of sand, silt, crap, etc from my frame rails on my 74 Monaco Police car during the resto......and ran / sprayed primer and paint in as best I could ...the trans line worked great, using the end to scrape away at the inside corners and get the packed silt...but do it outside trust me
"Put a Dodge in your garage!"
Re: What do you guys do for those hard to get to areas?? [Re: DaytonaTurbo] #851908
11/13/10 11:09 AM
11/13/10 11:09 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Thats rather personal.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: What do you guys do for those hard to get to areas?? [Re: mbmopar] #851909
11/13/10 03:13 PM
11/13/10 03:13 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
mbmopar: That's a great idea, thanks!
A nearby bodyshop uses a product called "wax-oil". It is sort of like the spray foam stuff used for sealing drafty windows and walls in your house. They put an extension tube on the wax-oil can and use it to fill the rocker panels and door bottoms. Sorry I don't have pics, perhaps someone else does?
Mo' Farts
Moderated by "tbagger".
Re: What do you guys do for those hard to get to areas?? [Re: Grizzly] #851910
11/14/10 09:18 AM
11/14/10 09:18 AM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Also add a shop vac with small nozzle or home made attachment to work inside and at the holes. Yuo can feel the dirt as it is scrapped and gathered. Old coat hanger will also loosen stuf if you feel around and work it back and forth. I spent hours on a car and was amazed how much dry south carolina red clay I got out.
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: What do you guys do for those hard to get to areas?? [Re: DaytonaTurbo] #851911
11/14/10 10:12 AM
11/14/10 10:12 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
While I haven't tried it, Eastwood now has a product for treating the inside of frame rails.
Worth a try?
Eastwood
John
Re: What do you guys do for those hard to get to areas?? [Re: SattyNoCar] #851912
11/14/10 11:48 AM
11/14/10 11:48 AM
None
71rm23 Offline
71rm23  Offline
None
Worth a try?
Eastwood
Thanks for posting that. I would give it a whirl
Re: What do you guys do for those hard to get to areas?? [Re: 71rm23] #851913
11/14/10 04:04 PM
11/14/10 04:04 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
I dont like the idea of filling the rockers up with something. I think it will just make it hold water and actuly rust it out faster.
Re: What do you guys do for those hard to get to areas?? [Re: magiccuda] #851914
11/14/10 04:05 PM
11/14/10 04:05 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Re: What do you guys do for those hard to get to areas?? [Re: magiccuda] #851915
11/15/10 12:02 AM
11/15/10 12:02 AM
SattyNoCar Offline
SattyNoCar  Offline
If you're referring to the product I posted a link to, its not foam. As long as the drains are clear, I don't see a problem.
John
Re: What do you guys do for those hard to get to areas?? [Re: Grizzly] #851916
11/15/10 03:03 AM
11/15/10 03:03 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
No, we were reffering to this one quoted above.
I would never put some kind of foamy element inside the rockers!!! I bet it would make things worse!!!
Re: What do you guys do for those hard to get to areas?? [Re: domingo] #851917
11/15/10 09:23 AM
11/15/10 09:23 AM
Appleton, Wisconsin
rtmike Offline
rtmike  Offline
Appleton, Wisconsin
I cleaned mine the best I could with compresed air and a shop vac. If there was surface rust I hit it with the spray stuff that turns the rust black (I think its phoshporic acid, but don't quote me, I got the semi-cheap version from NAPA), then I stuck the nozzle of the spray gun in there and put paint in there like crazy. It was messy, but in the end it is probably the best thing I could do. I am sure it is better then the factory, and that held up for 41 years, so considering how little weather it sees, probably good.
Its not primer its perma gray.
Re: What do you guys do for those hard to get to areas?? [Re: domingo] #851918
11/15/10 10:54 PM
11/15/10 10:54 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
Fluid film is a wax oil and it's pretty runny, not foamy?? I think cosmoline is also a wax oil??? Those two are great for inside panels, rails etc...
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: What do you guys do for those hard to get to areas?? [Re: DaytonaTurbo] #851919
11/16/10 02:26 AM
11/16/10 02:26 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
At my work we uae a product called seal out. You stick a long wand 4feet long in frame rail rockers backsides of fenders etc. The wand is attached to a siphon style gun. pull the wand out slowly and it shoots this stuff 360 degrees. Best rust fighter I know of. It seems to crawl around all over the place. Will drip out for a while ,but that is how you know if you got it good.
Re: What do you guys do for those hard to get to areas?? [Re: smac77] #851920
11/16/10 03:15 AM
11/16/10 03:15 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Ok, that sets me straight. Thanks for the clarification.
Mo' Farts
Re: What do you guys do for those hard to get to areas?? [Re: Grizzly] #851921
11/16/10 09:27 AM
11/16/10 09:27 AM
London, England
Gavin Offline
Gavin  Offline
London, England
You are probably thinking of this product Wayoyl (note spelling).
The product is better than the website! It has been used over here in the UK for decades and works pretty well - it is exactly designed for getting in hard to reach cavities etc and preventing rust. I'm sure it must either be available in the US or something similar.
Re: What do you guys do for those hard to get to areas?? [Re: Gavin] #851922
11/18/10 12:38 AM
11/18/10 12:38 AM
SattyNoCar Offline
SattyNoCar  Offline
Doing a quickie google search, I came up with these guys that apply waxoyl or sell it for the DYI'er.
Robinson Service
How difficult is it to apply this stuff?
John
Re: What do you guys do for those hard to get to areas?? [Re: SattyNoCar] #851923
11/19/10 08:27 PM
11/19/10 08:27 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Robinson Service
Not difficult - it is pretty much solid at room temeprature (but you could squish it in your hand easily). If you heat it up it gets real runny and then is easily applied inside sills etc with a sprayer. The ones you buy are basically like a trigger sprayer with a tube on with holes in it. It would be easy enough to make an applicator.
Only thing is - that link you posted seems to be charging over $200 for a 5L can - over here you can get a 5L can for less than $50. That seems excessive to me
Re: What do you guys do for those hard to get to areas?? [Re: Gavin] #851924
11/19/10 09:43 PM
11/19/10 09:43 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Sounds like Ziebart......
Re: What do you guys do for those hard to get to areas?? [Re: A12] #851925
11/21/10 10:44 AM
11/21/10 10:44 AM
SattyNoCar Offline
SattyNoCar  Offline
How much would you charge to ship?
Sounds kinda like Ziebart to me too.
John
