Re: mopar .590 colid and rpm heads
[Re: rook440]
#851604
11/11/10 11:39 PM
11/11/10 11:39 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Does anybody run the edelbrock rpm heads with the mopar .590 cam in their Big block ,,I have a set and Im thinking of putting them on the dart this winter ,it currently has 516 heads ,it weighs around 3300 lbs with driver.and has a 5000 stall converter ... any ideas on performance ???
A couple of racers I know use that exact combination.It works real well.You need to upgrade the valve springs to make it last.I use Comp 928's for that setup. Keith
[Re: Dunnuck Racing]
#851605
11/12/10 12:04 AM
11/12/10 12:04 AM
Posts: 9,867 MI, usa
dvw
MI, usa
We ran that combo in my buddys GTX. All steel,full interior,6 pt bar,8" converter ,4.56,torker,850,1 3/4 headers,12-1 Ross pistons,stock rods,3700 lbs. 10.83@123 best,10.90 in the heat anywhere. Doug
#851606
11/12/10 12:07 AM
11/12/10 12:07 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I had a typical trw piston/stock rod 440 with bagshaw ported 906's and hi-rate of lift .570 Hughes hydraulic cam, and it went consistant 10.80-10.90 in my 2900lb 70 Challenger with a glide. I put Eddie RPM's and a 590 on that shortblock, and the 2nd pass with no tuning was 10.69. The seventh pass I hit it with 250 out of the hole, and stacked 175 on it in 2nd... it kicked a rod at 1100 ft, and broke the cam in 3 places on it's way to a 9.21-141. That was the end of my experience with that combo!!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: RAY1969CARS]
#851610
11/12/10 06:37 AM
11/12/10 06:37 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I run the modern cyl heads rpm's, .590 cam, 12.5.1 in a 3200 Dart. Best time in my sig without any tuning yet and a slow 60 ft, previous run was 1.46, and against the limiter.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: rook440]
#851613
11/13/10 01:38 AM
11/13/10 01:38 AM
Posts: 266 iowa
rook440
iowa
[Re: SILVER67]
#851615
11/13/10 06:23 AM
11/13/10 06:23 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
hey mr rook my junk is similar to your question - 493 , eddy rpm's , .060 milled cam is flat tappet 611 lift , car is about 3200 without fat driver. 4500 stall - 410 gear with 29.5" tall tire lots of bugs and problems/ weather in 2010 , but it went 6.58 at 103 , and 10.40 1/4 , best 60' was 1.411 . like they all say -- I KNOW theres more in it send me a pm for my number , if you want to talk details or shoot the sht.
[Re: mopar65]
#851618
11/13/10 12:26 PM
11/13/10 12:26 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
what's your compression!!!!! that is a big factor in choosing a camshaft
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
