Re: Help checking piston to valve clearance?? [Re: 451Mopar] #851591
11/13/10 01:38 AM
11/13/10 01:38 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
It is difficult to estimate the Piston/valve clearance on paper unless you know the true cam lobe profile (duration at multiple lobe lift points), lobe seperation angle, and installed center-line.
The cams maximum lift does not mean much because the piston will have moved down in the cylinder quite a bit by then. Other information needed for an estimate would be the closed valve position to piston clearance at TDC, and the stroke/rod length to figure the piston movement around TDC.
Like I said, using math to estimate (model) the PV clearance is not easy.
The easy solution is checking with the actual cam installed. Both intake and exhaust will need to be checked. First you need to install your checking springs, a solid tappet (or tappet that won't compress under the checking spring load), and set the lash. Setting zero lash is best, you can add in lash to the PV numbers later.
With the dial indicator setup on the valve retainer, you just push the valve down till it contacts the piston and take the PV reading directly, but you have to do this at several crank positions because the least clearance point is unknown.
Usually the PV is tightest around 10-20 degrees Before (exhaust) and after (intake) TDC depending on the above mentioned cam parameters, including the cams installed position.
I agree, Jim. A situation like this is another reason I'd like to see cams sold with graphs instead of just the .050" number. So regardless of the piston profile dead accurate measurements could still be made.
Re: Help checking piston to valve clearance?? [Re: 64Post] #851592
11/13/10 02:50 AM
11/13/10 02:50 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Cam is 10 degrees retarded. Only one cymbal on the crank timing gear key way which is a V, nothing on the other two key ways. And I didn't have any keys for the cam timing gear. Can't finish up until Sunday.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Help checking piston to valve clearance?? [Re: Junky] #851593
11/13/10 03:03 AM
11/13/10 03:03 AM
That cant be right
Re: Help checking piston to valve clearance?? [Re: RapidRobert] #851594
11/13/10 08:34 AM
11/13/10 08:34 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
i always thought the sure fire way was to put clay on the piston, mock everything up and run it through a full sweep, then take it apart and measure the clay. if you feel contact/resistanct, then stop.
**Photobucket sucks**
Re: Help checking piston to valve clearance?? [Re: Junky] #851595
11/13/10 11:02 AM
11/13/10 11:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
383 engine with the heads on, engine in the car. Heads are the 346 kind.
The clay method works great because you can see where the valves match up with the reliefs in the piston, but you have to remove the cylinder head. The method I described works without removing the head.
Re: Help checking piston to valve clearance?? [Re: RapidRobert] #851596
11/13/10 01:50 PM
11/13/10 01:50 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
That cant be right
That does seem like a lot. We're going to go over it again Sunday.
Re: Help checking piston to valve clearance?? UPDATE [Re: Junky] #851597
11/15/10 12:31 AM
11/15/10 12:31 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
The exhaust clearance is .170 and the intake is .160, that's with .030 taken off the heads. So, I guess it can be said that a 383 with 30 off the heads, flat top pistons 20 in the hole can run a .518 lift cam. BTW, the cam is Hughes' Whiplash cam. Will have it running tomorrow.
Re: Help checking piston to valve clearance?? UPDATE [Re: Junky] #851598
11/17/10 01:56 AM
11/17/10 01:56 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
What's the verdict? Are you happy with the cam swap?
Re: Help checking piston to valve clearance?? UPDATE [Re: rss] #851599
11/17/10 12:56 PM
11/17/10 12:56 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I haven't had time to tune the engine. It sounds really healthy and winds to 6k with ease. It pulls hard. The tune on it now is more for the old cam. I need to work the distributor and carb over. Once I get it tuned up I'll post back the results.
Re: Help checking piston to valve clearance?? [Re: 70Cuda383] #851600
11/18/10 10:19 AM
11/18/10 10:19 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
He has the heads on the engine and doesnt want to pull them... i said the same thing earlier in the thread, for future this should be done before heads are on if the clearance is to tight what then? you cant fly cut the pistons with the heads on.. cart before the horse
Kevin
