torque converter balance weights, 70 440 Magnum
#85100
07/07/08 07:58 AM
07/07/08 07:58 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
Engine is a 70 440 Magnum with the 70-71-Magnum-specific external balance.
The transmission front seal blew out of my trans, in one day it went from an occasional drip to enough drips&runs to turn my car into a cropduster. I suspected this was more than a seal to start leaking so badly, and suspicions were confirmed.
The converter hub has a pretty wide wear patch on it, and I also noticed the converter has 2 ring gear teeth missing, which I could feel when starting the car (but didn't know what it was). The converter also has 2" tall lettering on the back side that has been painted over, so somebody has been in there before me (even though it's a 'survivor' car). I'm going to install a new pump bushing, seal, and new converter.
So: I've looked and haven't found anyone that lists this specific converter, and I've looked unsuccessfully for the data on the weight size and location so that I could weld them onto an unbalanced converter. Anyone got any info? My car always had a slight vibration (could feel it in neutral when revving the engine) so I don't trust using my existing converter weights or as a pattern.
Help!
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
Re: torque converter balance weights, 70 440 Magnum
[Re: 79powerwagon]
#85102
07/07/08 11:35 AM
07/07/08 11:35 AM
Fury Fan
Indiana
Is this the one? They only showed 2 for external balance for a 440, 1 for steel crank and 1 for cast -- it doesn't specifically mention the balance setup and it says it fits 66-78 bigblocks (which is a very wide paintbrush!). http://store.summitracing.com/partdetail.asp?part=BMM%2D10238&autoview=skuB&M doesn't even list this part on their website, so no info there...
Parts I seek:
Send a PM.
[Re: MoparforLife]
#85104
07/07/08 01:59 PM
07/07/08 01:59 PM
Fury Fan
Indiana
Yeah, I've considered this but my car always had a slight vibration (could feel it in neutral when revving the engine slowly). I don't trust using my existing converter weights as a pattern unless I can find out that they are the right size and right location.
If anyone with a stock 70-71 440Magnum can take their inspection cover off, measure the weights and take a pic that would help me greatly! Or a tech drawing would work instead - I've seen this data on flywheel balancing but not found it for the converters...
Parts I seek:
Send a PM.
[Re: Fury Fan]
#85105
07/07/08 04:34 PM
07/07/08 04:34 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
B&M #10238 is the correct flexplate for the '70 440HP.
