Re: Dim and Bright lights in the dash
[Re: cornet684me]
#850880
11/14/10 07:28 PM
11/14/10 07:28 PM
Posts: 5,439 So Cal
Sinitro
So Cal
i really do not have a major problem, i have replaced all the bulbs, while driving down the highway all the interior lights are fine, the problem is at idle, the interior lights get kinda of dim, however asap when i go back to driving again everything is fine, it is more a personal thing , i do not like the dim lights at idle, so what everyone is saying, the best fix will be changing out the alternator?
Another basic question.. What is the idle RPM? The lower this is, the less voltage the alternator will put out..
Just my $0.02...
[Re: Sinitro]
#850881
11/14/10 08:25 PM
11/14/10 08:25 PM
RapidRobert
Good stuff. Clean all connections including grounds esp the bulkhead in/out or better yet Nacho's simple 2 wire bypass. 78 amp squareback from late 70's iirc (maybe 80's). attach stereos etc to the alt side w relays including the headlights. If want to bypass the ammeter run an 8ga from alt to starter relay protected w a 12ga fusible link and also a FL at the alt output. there's 2 sizes of alt pulleys & I would use the smaller one
[Re: hooziewhatsit]
#850883
11/14/10 08:53 PM
11/14/10 08:53 PM
RapidRobert
When I was diggin thru my stash I saw 2 sizes but didn't measure either one but I would think yours unfortunately is the smaller one. EDIT pic is much larger (posted) than what it shows on my computer. You can see which one you have
[Re: cornet684me]
#850888
11/14/10 09:54 PM
11/14/10 09:54 PM
Posts: 565 IA
landon1
IA
adding relays made a HUGE difference on my car with the brightness of the headlights. my stock dash lights always flickered a bit, but i don't recall how they acted after adding relays and now i run aftermarket gauges.
'71 Satellite Sebring 440
[Re: hooziewhatsit]
#850891
11/15/10 12:18 AM
11/15/10 12:18 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Found a diagram in my photos....
[Re: cornet684me]
#850895
11/15/10 12:27 AM
11/15/10 12:27 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
randy, is this a pic of the 40a rely?
Randy, I accidentally linked the wrong photo... The relays you want can be had at any car stereo/alarm store.. Get the relay harness too...
