Page 1 of 3 1 2 3
Dim and Bright lights in the dash #850860
11/11/10 02:40 AM
11/11/10 02:40 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i have a 68'dodge coronet , i was told that there is a way to wire a wire from the alternator to the battery to stop the dim and flickering lights in the dash, when the car is at idle, the dash lights are dim, when i give the car gas, the dash lights and all the lights get brighter, does anybody know the trick to getting brighter lights at all times?
Re: Dim and Bright lights in the dash [Re: cornet684me] #850861
11/11/10 06:39 AM
11/11/10 06:39 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
There are a number of post from a guy named nachort74 here on the board - he's the guru in my eyes about that...
So the "trick" would be a stronger alternator that can load the battery in idle.
First I would recommend to attach a voltmeter to check voltage at the battery when idling and at about 2000rpm.
(The trick "with the cable" is to fix melted bulkhead connectors at firewall or even ampere-meters - but if you check your battery you will find out if any bad connecitons are your problem)
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Dim and Bright lights in the dash [Re: Swiss_Robert] #850862
11/11/10 02:07 PM
11/11/10 02:07 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Mopar did a "bad thing" with wiring in these, especially now that folks want to run stereos, pumps, fans, etc. ALL the high power conductors for the vehicle go through the bulkhead connector, sometimes two or three times, IE Alternator feed comes IN to ammeter, back OUT to battery, then headlights go OUT to lights, etc.
Also it has been alleged that the internal design of the older alternators (round back) are such that they simply do not "put out" much at low RPM.
I cannot personally confirm this, it may be true. You CAN use a newer "squareback" 70/ later alternator on your 69, by grounding the second field terminal.
So a combination of upgrading the alternator and look up the "Mad electrical" articles on ammeters and bulkhead connectors.
If you aren't a "concourse" freak, there are some ways to upgrade the wire size and keep the ammeter. One way is to drill out the bulkhead connector and slip larger wires right through with no connectors on them.
Also, on your dash lights::
Clean grounds, clean the sockets, clean or replace the bulbs. Make sure the bulbs are the recommended part no. There are MANY different bulb wattages of the same bulb size, so if you get a "heavy" bulb in one hole and a "light" bulb in another, you'll have a big difference in brightness.
Dirty, corroded instrument lamp dimmers don't help, either. You can actually reach a situation where as the charging voltage drops, the rusty wiper on the dimmer can start to arc and lose connection. Most of the time you can just twist the dimmer back and forth vigorously to clean up the slider.
Re: Dim and Bright lights in the dash [Re: cornet684me] #850863
11/11/10 04:10 PM
11/11/10 04:10 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Time to kleen the bulkhead connectors..
Unsnap each, wire brush the connectors and apply dia-electric grease. Replace any terminal that is damaged, replacements available from Napa.
Keep in mind...
The electrical systems in our ole Mopars was designed to handle a max of about 40 Amps..
If one has added electric fans, fuel pump, subwoofer amplifier the system need to be beefed up.
Just my $0.02...
Re: Dim and Bright lights in the dash [Re: Sinitro] #850864
11/11/10 09:41 PM
11/11/10 09:41 PM
BDW Offline
BDW  Offline
Add a jumper from the alternator to the battery, worked wonders for me.
http://www.allpar.com/history/mopar/electrical.html
Re: Dim and Bright lights in the dash [Re: BDW] #850865
11/12/10 11:53 AM
11/12/10 11:53 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
After all is said and done put a smaller diameter drive pulley on the alternator.
Re: Dim and Bright lights in the dash [Re: cornet684me] #850866
11/12/10 12:25 PM
11/12/10 12:25 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Read up on http://www.madelectrical.com/ how to bypass the amp meter and how to rewire. Install a volt meter. Install a Denso alternator. I did this on my Coronet. No more dim lights.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Dim and Bright lights in the dash [Re: MO_PA] #850867
11/12/10 01:52 PM
11/12/10 01:52 PM
Montana
Y
Y
Montana
Not all that great an idea. "Back when" I was roaring around Sand Diego in my '70, it had the "optional" 60-65? amp alternator. Small pulley ona 440sixpack. After 2 failures, I figured out the ratio. 4:1 !!!!??? This means that when the engine is spinning at 5K, the alternator is spinning.........20,000 RPM!!!!
The windings vibrate inside, and scrape the insulation off "themselves," the little pins that the stator indexes onto in the cases wear, and allow the stator to get out of alignment. In one case, the stator was hitting the rotor!!!
I ran a Delco back then!!! This was 1973
Re: Dim and Bright lights in the dash [Re: cornet684me] #850868
11/12/10 02:11 PM
11/12/10 02:11 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
First...
Fix the bulkhead connectors..
A bigger alternator and/or pully change will not correct the problem if there are bad, oxidized connections.
Just my $0.02...
Re: Dim and Bright lights in the dash [Re: cornet684me] #850869
11/12/10 03:14 PM
11/12/10 03:14 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
As many posters have stated, it's a multi-issue problem. It's best resolved addressing the bulkhead issue, the ampmeter issue, upgrading the alternator wiring in both size and routing and if you are running anything more than a stock electrical load, swaping out the Mopar alternator for one of the many replacemnts that have been successfully used. One of the strongest alternators at idle is a Delco-Remy product. Check out this link.
https://board.moparts.org/ubbthreads/show...e=3#Post6295580
Re: Dim and Bright lights in the dash [Re: BDW] #850870
11/13/10 01:40 AM
11/13/10 01:40 AM
Brandon, Ms
Brandon, Ms
hey Wilson, that is the thing i had heard to do that is a simple fix, i read this article you gave me link too, so i run the wire from the starter rely to straight over to the alternator?
Re: Dim and Bright lights in the dash [Re: jbc426] #850871
11/13/10 01:42 AM
11/13/10 01:42 AM
Brandon, Ms
Brandon, Ms
i have disconnected the amp meter and connected the wire together under the dash already
Re: Dim and Bright lights in the dash [Re: cornet684me] #850872
11/13/10 01:44 AM
11/13/10 01:44 AM
Brandon, Ms
Brandon, Ms
i really do not have a major problem, i have replaced all the bulbs, while driving down the highway all the interior lights are fine, the problem is at idle, the interior lights get kinda of dim, however asap when i go back to driving again everything is fine, it is more a personal thing , i do not like the dim lights at idle, so what everyone is saying, the best fix will be changing out the alternator?
Re: Dim and Bright lights in the dash [Re: cornet684me] #850873
11/13/10 03:04 AM
11/13/10 03:04 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
How many wires does the alternator have on the back of it? (2)One bigger one and one smaller one, or (3)one bigger one and two smaller ones?
If you only have 2, you can buy and install the dual field alternator (3 wire) and that will solve the low rpm pulsing of the lights.
You will want to install a bigger, big wire from the alternator stud to the starter relay. Be sure to use the correct size fuseable link on the end of it at the relay.
Re: Dim and Bright lights in the dash [Re: jbc426] #850874
11/13/10 03:18 AM
11/13/10 03:18 AM
Montana
Y
Y
Montana
There's been some discussion that the older (69/earlier) alternators had a design which prohibited decent low rpm output, and that the later-frame units solved this. So long as your wiring is "up to snuff" AND IT'S not a wiring problem in the regulator circuit, or the regulator itself, you might indeed improve things by swapping up to a later model alternator.
If you want to try it, as noted above, you only need to ground the second field wire.
However, without much additional work, you can add just one more wire, and convert to the '70 and later electronic regulator, as well
Re: Dim and Bright lights in the dash [Re: cornet684me] #850875
11/13/10 10:23 AM
11/13/10 10:23 AM
BDW Offline
BDW  Offline
It's really that simple. As stated make sure you use appropriate gauge wire with a fusible link.
Re: Dim and Bright lights in the dash [Re: BDW] #850876
11/13/10 02:00 PM
11/13/10 02:00 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Educate yourself by reading this. Then purchase and install a Denso alternator. All problems solved.
From my experiences, the square back and the round back alternators have the same low idle problems. Not enough output to keep the lights bright.
Take a look at AndyF's Denso setup.
Re: Dim and Bright lights in the dash [Re: Junky] #850877
11/13/10 02:38 PM
11/13/10 02:38 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not agreed on madelectrical solution as many of you know from me.
depending what squareback alt you choose. Stock 78 amps are available fro cheap ( $500 without core return ) and even they are not THE BEST OF ALL ( they are still some unneficient at iddle for the max output rate stated ) but they will solve the problems in the old school Mopar way. They put at iddle around 40-45 amps, what is in mostly of old Mopars the max alt output mounted
But average, yes, round and squarebacks alt are pretty much the same, simply squarebacks are easier to service.
elec or mech regulator is more relate with regulation eficiency not really with alt output, but of course a more efficience reg will result on a better charge capability with less power missing. Then also will save from "electrical noises" on electronic devices.
They mopar alt problem is more related with stator windings design than all the alt itself
if you don't care about old school mopar look, thats a great solution. If you care, you have 100 amps Tuff Stuff alts assemblied on old kind housings.
Re: Dim and Bright lights in the dash [Re: Junky] #850878
11/13/10 05:06 PM
11/13/10 05:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Some good advice, but if he doesn't have any aftermarket electrical load a squarback will be more than enough to stop the low idle issues.
Denso's will work, but aren't much better compared to what's available these days. How about a CS144 with 80 to 115 amps at idle and 140+ just above idle. Bolts on to the stock mount with a $30 adaptor.
Re: Dim and Bright lights in the dash [Re: jbc426] #850879
11/14/10 04:12 PM
11/14/10 04:12 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
JUST the right one, not anyone
Page 1 of 3 1 2 3
