Demon 850 ? #850834
11/10/10 11:51 PM
11/10/10 11:51 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Both the front and rear accelerator pumps have leaked off and on since the car has gone together. Has anyone else had this problem? I have taken them both off several times and checked them for obvious signs of damage, but I have not seen anything that would indicate a problem. I have even replaced them in case I overlooked something I can't actually see. Is there a better carb. I should consider for a street/strip car?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Demon 850 ? [Re: BloFish] #850835
11/12/10 12:03 AM
11/12/10 12:03 AM
Check the reataining screw lengths to make sure there not bottoming out before tightening up on the housing the diaprhams are siting in You might need to grind or shorten the lengths of those screws
Re: Demon 850 ? [Re: Cab_Burge] #850836
11/12/10 03:05 AM
11/12/10 03:05 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree, had this happen before when i modified a 3310 rear bowl, if they are not just right they WILL leak, Don't understand why in your situation they would leak (especially if it was a new carb) unless you got it used & someome changed the screws, also make sure the 2 surfaces are true & flat.
Other then a ripped or punctured diaphram/too long of screws or surfaces not being flat theres no reason they should leak, there are fixable, so no need getting a whole other carb.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Demon 850 ? [Re: joedust451] #850837
11/17/10 11:20 PM
11/17/10 11:20 PM
On the run…
BloFish Offline OP
BloFish  Offline OP
On the run…
Their tech support person suggested replacing the Renee Valves
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Demon 850 ? [Re: BloFish] #850838
11/17/10 11:51 PM
11/17/10 11:51 PM
UK
602heavy Offline
602heavy  Offline
UK
I had this problem with an 850 mighty , after head scratching for a while it turned out underside of float bowls were cracked.
Re: Demon 850 ? [Re: BloFish] #850839
11/18/10 02:57 AM
11/18/10 02:57 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Sell it and call PC Carb in So. Cal. I personally have not messed with a Demon carb, but I have heard plenty of people that struggle with them. Thats not saying that the person may not have been 100% familiar with what they are doing but they had problems none the least. PC Carb in Ontario California has never let me down with there builds. I build several engines per year and they all get PC Carbs on them. No problems EVER and they ALL run beautifully.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
