There is definitely a difference. On ball joints it can mean the difference between using nylon bushings and steel, or the difference between foreign and US made. I use rockauto religiously and for chassis parts I only buy premium line stuff. You get what you pay for with chassis stuff. All of the lower and mid grade tie rod ends, for example, will be cast bodies while only the Moog, have I ever seen, are forged ends. Worth paying for, to me.
2003 Mercury Marauder, 34k miles, 3.73s and custom flash tuned 1981 Camaro, 350 w/ Holley Stealth Ram MPEFI, Sportsman heads, roller cam, self-burned chips, wideband O2 1983 Firebird TA 1993 Saturn SL2 83k
