Page 1 of 3 1 2 3
Polara 500 engine #850229
11/09/10 10:15 PM
11/09/10 10:15 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
I recently bought a 62 Dodge Polara 500 and Im trying to figure out what engine it has. My only problem is the numbers and letters on the block make no sense. Doesnt say 361 or 383. It says H4O across the top then a 3 and then on the other side an 8 and below an E.
H 4 O
3 8
E
Re: Polara 500 engine [Re: moon] #850230
11/09/10 10:20 PM
11/09/10 10:20 PM
Under My Car
Mopar_Country Offline
Under My Car
Look on the front of the engine right below the head on the driver side. Let us know what you see.
Re: Polara 500 engine [Re: moon] #850231
11/09/10 10:54 PM
11/09/10 10:54 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
The 361 was standard in 1962 Dodge Plolara's.
The 383 was not offered!
Re: Polara 500 engine [Re: moon] #850232
11/09/10 11:19 PM
11/09/10 11:19 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
S 36=361
S 38=383
S 41=413 These are 62# 63 same except T before #
Right side of block below dist. 383's were offered,not sure if in a Polara.
Re: Polara 500 engine [Re: moon] #850233
11/10/10 06:19 PM
11/10/10 06:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
H 4 O
3 8
E
H is the year code for 1972 so it is a '72 400 built on March 8, 1972; the E means it has a cast crank.
Re: Polara 500 engine [Re: John_Kunkel] #850234
11/10/10 08:35 PM
11/10/10 08:35 PM
Amherst,NY
challengermike Offline
Amherst,NY
wouldnt it be easier to just look at the side of the block and get the casting #.It should say the engine size and year.
Re: Polara 500 engine [Re: moon] #850235
11/10/10 08:49 PM
11/10/10 08:49 PM
AndyF Offline
AndyF  Offline
Yep, sounds like a '72 400 has been swapped in there. Crawl underneath and see if there is a VIN stamp on the pad. Depending on how dirty the motor is you might also be able to see the casting number and/or date.
If the engine has a cast crank damper then that should be a clue that it is from a later model car.
Re: Polara 500 engine [Re: AndyF] #850236
11/10/10 10:27 PM
11/10/10 10:27 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Im positive the car is a 1962 Dodge Polara 500, so it wasnt made in 1972. Its a 1 owner car, Im the 2nd. It has a steel crank and small harmonic balancer. Still has the points distributor, small port AFB carb, original air cleaner and it still has bolt-up tranny6 front drive line. Ill look under the car tomorrow to fund more numbers. Thanks for comments so far.
Re: Polara 500 engine [Re: moon] #850237
11/10/10 11:20 PM
11/10/10 11:20 PM
AndyF Offline
AndyF  Offline
Something could've happened to the original engine block and all the parts were swapped over to a later model block. If the block says H40 with an E on the ID pad then that is most likely a '72 400. Either that or someone restamped an original block with some odd numbers. Sounds like you won't know what you have until you look at the casting numbers.
Re: Polara 500 engine [Re: AndyF] #850238
11/11/10 12:40 AM
11/11/10 12:40 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Couldnt stand the wait so I braved the cold and wind to get the numbers off the underside of the block. 36142302 is what I found, so I believe I found a 361BB
Re: Polara 500 engine [Re: moon] #850239
11/11/10 01:29 AM
11/11/10 01:29 AM
AndyF Offline
AndyF  Offline
No, that is a 1972 400 that you have. 3614230 is a 1971-72 400 block. Someone swapped in a later model engine at some point.
Re: Polara 500 engine [Re: moon] #850240
11/11/10 01:29 AM
11/11/10 01:29 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
That block is a 1971-1972 400. The casting number should actually read like this 3614230-2. The "-2" is a mold number and not generally cited when mentioning the rest of the casting number.
Some of these "230" 400 blocks are pretty desirable, but it depends greatly on the casting date and if it will pass a sonic test on the cylinder walls.
Check your casting date, it will be on the driver's side next to head/deck surface.
Re: Polara 500 engine [Re: moon] #850241
11/11/10 01:31 AM
11/11/10 01:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If it were a 361 the block casting # would be 2205712
3614230-2 is a 71-72 400
Re: Polara 500 engine [Re: 1_WILD_RT] #850242
11/11/10 11:53 AM
11/11/10 11:53 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Well you all may be right, I never asked the old lady if it had an engine swap. They bought it new and I didnt see any changes when I looked at it. I guess its still worth the $2000 I paid for it. Thanks for all your help guys.
Re: Polara 500 engine [Re: moon] #850243
11/11/10 11:55 AM
11/11/10 11:55 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Here are a few pics of my car
Re: Polara 500 engine [Re: moon] #850244
11/11/10 11:56 AM
11/11/10 11:56 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
And the interior of the 62
Re: Polara 500 engine [Re: moon] #850245
11/11/10 11:57 AM
11/11/10 11:57 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
At least the engine runs fine...
Re: Polara 500 engine [Re: moon] #850246
11/11/10 12:10 PM
11/11/10 12:10 PM
6T4 Polara Offline
6T4 Polara  Offline
Good buy enjoy your new car.
John
Re: Polara 500 engine [Re: moon] #850247
11/11/10 01:26 PM
11/11/10 01:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
very nice!
Re: Polara 500 engine [Re: moon] #850248
11/11/10 03:02 PM
11/11/10 03:02 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Nice car!
Page 1 of 3 1 2 3
