Page 1 of 11 1 2 3 10 11
True Street car ET's #849673
11/09/10 05:40 PM
11/09/10 05:40 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Just curious..
What kind of ET's are you guys running that are true street cars.
Let me define "street cars" for this post.
Functional headlights/tail lights
Inspection sticker and can pass inspection for thier state
No lexan front windshields or side glass
Pump gas (E-85 ok)
Tagged and Insured
Full interior
Drive it the way you run it!
Im not trying to eliminate people/cars. I just want to see what is out there. Not a race car that can be driven on the street with a few changes, etc.
Re: True Street car ET's [Re: TheOtherDodge] #849674
11/09/10 05:45 PM
11/09/10 05:45 PM
Guitar Jones Offline
When I drove my Duster on the street, full exhaust, street tires, belt driven water pump and all with a W2 340 I could just lower the tire pressure and run 11.70's in the Florida heat.
Re: True Street car ET's [Re: TheOtherDodge] #849675
11/09/10 05:47 PM
11/09/10 05:47 PM
an8sec70cuda Offline
9.50s at 140 mph on motor. I race it the same way I drive it on the street w/ the exception of the mufflers. It's been 9.50s w/ the race bullet mufflers. I street drive it w/ Flowmasters...been 9.60s w/ them on it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: True Street car ET's [Re: an8sec70cuda] #849676
11/09/10 05:53 PM
11/09/10 05:53 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
11.84 so far. I think it needs to be faster yet, but I'm working on it. Drive there, run, drive home.
Re: True Street car ET's [Re: Jeff_383] #849677
11/09/10 06:00 PM
11/09/10 06:00 PM
Ma
Voluster Offline
Voluster  Offline
Ma
10.28 at 130mph on 275 drag raidals
3460 with me in it
Re: True Street car ET's [Re: Voluster] #849678
11/09/10 06:04 PM
11/09/10 06:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
10.5s @ 126 MPH on 275/60R15 ET Street Radials weighing 3755#s w/ driver.
I drive it in, set the tire pressures, and blast off.
Re: True Street car ET's [Re: Jeff_383] #849679
11/09/10 06:04 PM
11/09/10 06:04 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
11.57 @ 117.86 mph so far. (Ran 11.64 @ 118.26 on a previous pass the same day.)
This is in 100% street legal trim. Air cleaner, full exhaust back to the rear valance, and with the car seat still installed in the back seat.
The way we race it is the same way you see us driving the car down the highway or around to the local cruise nights/shows.
Cast crank 440 w/ 906 heads.
Edit: No power adders of any kind either.
Re: True Street car ET's [Re: Blues_Cuda] #849680
11/09/10 06:20 PM
11/09/10 06:20 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
10.91 so far in stupid heat. Full interior ,heater, wipers, Et streets. No spray street car.
6.50 @105.26
Re: True Street car ET's [Re: TheOtherDodge] #849681
11/09/10 06:22 PM
11/09/10 06:22 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
My best is in my sig. Original owner, full interior, no light weight parts other than the hood.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: True Street car ET's [Re: TheOtherDodge] #849682
11/09/10 06:29 PM
11/09/10 06:29 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
11.0 at 123 in mid 90s heat, 2000+ ft DA
Hope to get out at least one more time before it gets too cold or the tracks close, it should be good for 10s in the cooler weather we have now.
No trailer here yet, so wherever it needs to go it goes under it's own power.
Rich H.
Esse Quam Videri
Re: True Street car ET's [Re: ZIPPY] #849683
11/09/10 06:35 PM
11/09/10 06:35 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
12.64 best in mine.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: True Street car ET's [Re: ZIPPY] #849684
11/09/10 06:37 PM
11/09/10 06:37 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Zippy at 123mph you have a lot left in it. good air should bring you some 70s or 60s. Go back out before it's too cold.
6.50 @105.26
Re: True Street car ET's [Re: Kindafast] #849685
11/09/10 06:51 PM
11/09/10 06:51 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Thanks for the encouragement
The worst part has been watching the videos of it 1000 times and looking at all that wheelspin At the time I was happy to be there and running at all, and was trying to stay cool.
Changed out some suspension stuff, plan on launching differently too...that and better weather should get it there...just need to find the time now. If not there's always spring, but it'd be nice to get it done sooner!
Rich H.
Esse Quam Videri
Re: True Street car ET's [Re: ZIPPY] #849686
11/09/10 06:57 PM
11/09/10 06:57 PM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
Mine runs 12.40s @ 107mph 10.92 @ 122.mph on 175 shot 275/60 drag radials,3500lbs with me in it.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
Re: True Street car ET's [Re: mphsmitch] #849687
11/09/10 07:37 PM
11/09/10 07:37 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
8.97 at 157 is my best and I know that the car would go 8.20's as it sits with some time learning the boost controller
Re: True Street car ET's [Re: joshking440] #849688
11/09/10 07:52 PM
11/09/10 07:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've driven mine from N.W. Detroit to Columbus a couple of times. 11.01@124 best. Last time out at the Classic at Norwalk 11.11@121. Stock suspension with a couple of extra leaves and adjustable rear shocks. 3875 w/me in it. A.C. stuff is still in the dash,no electric water pump. 340+.030" W/ a worn out diesel blower mounted on a 4 barrel intake.
Doug
Re: True Street car ET's [Re: joshking440] #849689
11/09/10 07:52 PM
11/09/10 07:52 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
consistant 10.50's with mufflers and dot radials. even pulls the wheels off the foot brake. 10.6:1 compression 408.
Re: True Street car ET's [Re: mopar dave] #849690
11/09/10 07:58 PM
11/09/10 07:58 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Not to hijack, but I'd really like to know the rest of that motor/converter/gear combo...
What's it weigh??
Re: True Street car ET's [Re: cudadoug] #849691
11/09/10 08:23 PM
11/09/10 08:23 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
sure, car weights 3360 with me,just reweighed it.
indy intake,indy 360-1 heads ported to 228cc's,268/272@50-.714/.688-108 solid roller,5400 dynamic 8",727,4.10 gear on mickeys 325/50. the carb is a bigs 950 stage 5 plus and works awesome. i think that covers it.
Re: True Street car ET's [Re: cudadoug] #849692
11/09/10 08:24 PM
11/09/10 08:24 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I agree, I also have a coupe with a 408, but mine only goes 10.86 w/open headers on a 10.8:1 408. I second that on hearing about that combo.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
