Rocker Arm torque specs? #84951
07/06/08 07:46 PM
07/06/08 07:46 PM
OH-IO
moparman383 Offline OP
OH-IO
I am putting my 383 back together and can't find the torque specs to put my rocker arms back on. The motor is not stock, the heads are edelbrocks and the rocker arm/rockers is from crane.
Any info is appreciated. Thanks!
Re: Rocker Arm torque specs? [Re: moparman383] #84952
07/06/08 08:04 PM
07/06/08 08:04 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
FSM in front of me here says 25 ft. pounds for BB rocker shaft bolts.
Re: Rocker Arm torque specs? [Re: mopowergtx] #84953
07/06/08 08:08 PM
07/06/08 08:08 PM
OH-IO
OH-IO
Thanks!
Did it happen to say to tighten in stages up to 25lbs?
To make sure we are on the same page, I am asking about the 2 bolts on the ends and the 2 nuts in the middle of the shaft.
Re: Rocker Arm torque specs? [Re: moparman383] #84954
07/06/08 08:16 PM
07/06/08 08:16 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
HUH? Dont you have stock type rocker shafts with 5 pedastal mounts?
Re: Rocker Arm torque specs? [Re: mopowergtx] #84955
07/06/08 09:31 PM
07/06/08 09:31 PM
OH-IO
OH-IO
Yeah, I typoed. It has 3 bolts and 2 nuts in the middle. Sorry.
Re: Rocker Arm torque specs? [Re: mopowergtx] #84956
07/06/08 09:34 PM
07/06/08 09:34 PM
i would minus 10ft-lbs off of that. ask me how i know.
Re: Rocker Arm torque specs? #84957
07/06/08 11:02 PM
07/06/08 11:02 PM
OH-IO
OH-IO
The lifters are already full of oil and under pressure, so when I tighten them down I am afraid of all that pressure tightening them down might strip the threads in the aluminum heads.
Any thoughts on this?
FYI: all I did was take the heads off to change the gaskets, didn't drain the oil, nothing was done to the engine, etc. Just replaced gaskets and sealed what I could off and gave it a quick paint job.
Re: Rocker Arm torque specs? [Re: moparman383] #84958
07/06/08 11:43 PM
07/06/08 11:43 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Edelbrocks? Just turn them down a little at a time and switch from time to time and keep the shaft level while tightening. Also keep an eye on pushrods that may want to fall out of the rocker arm seat.
Re: Rocker Arm torque specs? [Re: moparman383] #84959
07/06/08 11:44 PM
07/06/08 11:44 PM
thoughts? yup.. seen lots of pulled out threads when going to factory torque specs.
i swear chrysler made a typo in the FSM's.
Re: Rocker Arm torque specs? #84960
07/07/08 10:02 AM
07/07/08 10:02 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
25ft pounds is too much IMO. Mike
Re: Rocker Arm torque specs? [Re: mopars4ever] #84961
07/07/08 11:46 AM
07/07/08 11:46 AM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Remember this is a Big Block with the 3/8" bolts not the small block with the 5/16" bolts. 25 ft lbs on a 3/8" bolt isnt extreme. Small block grade 5 5/16" bolts would probably be stretching at 25 lbs.
And for typo's in FSM, for fun if you got one, look up the torque specs for a small block rocker shaft bolt in the 1969 Plymouth manual. It says 40 ft lbs! I'd like to see you get a 5/16" grade 5 bolt evan close to that before it breaks in half. 20 lbs on them scares me that they are stretching.
Re: Rocker Arm torque specs? [Re: mopowergtx] #84962
07/07/08 09:45 PM
07/07/08 09:45 PM
never did i say "broke the bolts". just the threads letting go ona big dude.
Re: Rocker Arm torque specs? #84963
07/08/08 09:46 AM
07/08/08 09:46 AM
Ive scared myself tightening these bolts to 25 as well. I don't do that anymore.... I go to 15. It just seems like either the threads are pulling out or the shaft is crushing- you know that feeling you get right before you strip out a bolt? thats the feel of going to 25 ftlbs
Re: Rocker Arm torque specs? #84964
07/08/08 12:27 PM
07/08/08 12:27 PM
OH-IO
OH-IO
My problem is that the lifters have oil in them and some are under pressure, so trying to tighten the shaft in equal increments is almost impossible because some are tight with 1 turn and others are way loose.
We were wondering if we should push the oil out of the lifters first so we don't overtighten and strip the bolts. Any thoughts on this?
Re: Rocker Arm torque specs? [Re: moparman383] #84965
07/08/08 12:34 PM
07/08/08 12:34 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
On hydraulic lifters that are already pumped up and stock type stamped rockers I've had good luck either using a 3/8 speed handle, or choking way up on a ratchet, and very gradually/very slowly working the bolts down a little at a time. Eventually the shaft will bottom out on the pedastals and when it does, THEN I torque to spec in 2 or 3 increments to make sure I'm not being fooled. If the job is rushed and the bolts individually reefed on, something will get screwed up for sure.
Solids are easier!
Rich H.
Esse Quam Videri
Re: Rocker Arm torque specs? [Re: ZIPPY] #84966
07/08/08 12:43 PM
07/08/08 12:43 PM
OH-IO
OH-IO
Mine are hydraulic. That's what I was afraid of - false readings because the shaft has not bottomed out. Thanks for the help!
Re: Rocker Arm torque specs? [Re: moparman383] #84967
07/08/08 12:47 PM
07/08/08 12:47 PM
i would be more concerned about the spring pressure that the hydraulic lifter being pumped up- unless of course your lift is so high that you bottom out a valve.
Re: Rocker Arm torque specs? [Re: ZIPPY] #84968
07/08/08 06:09 PM
07/08/08 06:09 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Thats how I've always done them myself. Watch to see when the shaft is tight on the pedastals and give a little bit more choked up on a 3/8" ratchet and never had a problem. I had my shafts on and off several times on my recent SB build and the first time I torqued them to 18 ft lbs and didnt like it. Went back to my old "feel" way. But I wouldnt be afraid on an iron head BB with the 3/8" bolts going to 25 ft lbs with a torque wrench. But anything over a little squeeze past flush on the tightening seems unecessary anyway.
Re: Rocker Arm torque specs? [Re: mopowergtx] #84969
07/08/08 06:36 PM
07/08/08 06:36 PM
some of you guys are putting WAY to much faith in those threads.
but thats just my opinion.
Re: Rocker Arm torque specs? #84970
07/08/08 07:16 PM
07/08/08 07:16 PM
Kirkland, Washington
Pacnorthcuda Offline
Crushing the shaft is a bigger concern, but I've been using 25ftlbs on BB for a long time and never had a problem.
