Turbo or supercharger?
#849556
11/09/10 12:39 PM
11/09/10 12:39 PM
Posts: 1,281 wisconsin
kmfdm
wisconsin
So I'm thinking about building a turbo or supercharged small block for my Dart. The only thing set in stone is that I'll be using my W-2 heads. Does it make sense to use a 340 or 360 or should I build a stroker for it? I have a bunch of other questions as well, but those can wait until I get some more info.
74 Dart Sport
Re: Turbo or supercharger?
[Re: Mr.Yuck]
#849558
11/09/10 03:57 PM
11/09/10 03:57 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
Here's some basic questions:
how much power? Street driven? how much? how many days at the track? race or pump gas? alchohol? $$$ to spend? fabrication skills?
Like said, turbo installations require a ton of fab work, but ultimately are a more efficient design.
Supercharger setups are almost turn key, kits are everywhere for SBM.
The rest of my answers are based on the questions above....
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
[Re: TheOtherDodge]
#849560
11/09/10 06:17 PM
11/09/10 06:17 PM
kmfdm
wisconsin
I'm looking for street/strip with more emphasis on street. I'd like to be able to drive it to the track when I want to though. I want around 600 to 650 horsepower but I don't want it to be a pain to drive. Pump gas is a must.
74 Dart Sport
[Re: kmfdm]
#849562
11/10/10 01:19 PM
11/10/10 01:19 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Turbo. Go with a mild engine build. Use a turbo specific cam and a basic block setup. Spend a little money on the heads but put most of it to EFI.
