Re: Rocker Arm torque specs?
[Re: mopowergtx]
#84956
07/06/08 09:34 PM
07/06/08 09:34 PM
FSM in front of me here says 25 ft. pounds for BB rocker shaft bolts.
i would minus 10ft-lbs off of that. ask me how i know.
[Re: moparman383]
#84959
07/06/08 11:44 PM
07/06/08 11:44 PM
thoughts? yup.. seen lots of pulled out threads when going to factory torque specs. i swear chrysler made a typo in the FSM's.
[Re: mopars4ever]
#84961
07/07/08 11:46 AM
07/07/08 11:46 AM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
25ft pounds is too much IMO. Mike
Remember this is a Big Block with the 3/8" bolts not the small block with the 5/16" bolts. 25 ft lbs on a 3/8" bolt isnt extreme. Small block grade 5 5/16" bolts would probably be stretching at 25 lbs.
And for typo's in FSM, for fun if you got one, look up the torque specs for a small block rocker shaft bolt in the 1969 Plymouth manual. It says 40 ft lbs! I'd like to see you get a 5/16" grade 5 bolt evan close to that before it breaks in half. 20 lbs on them scares me that they are stretching.
[Re: mopowergtx]
#84962
07/07/08 09:45 PM
07/07/08 09:45 PM
never did i say "broke the bolts". just the threads letting go ona big dude.
#84963
07/08/08 09:46 AM
07/08/08 09:46 AM
Ive scared myself tightening these bolts to 25 as well. I don't do that anymore.... I go to 15. It just seems like either the threads are pulling out or the shaft is crushing- you know that feeling you get right before you strip out a bolt? thats the feel of going to 25 ftlbs
[Re: moparman383]
#84965
07/08/08 12:34 PM
07/08/08 12:34 PM
Posts: 17,848 S.E. Michigan
ZIPPY
S.E. Michigan
On hydraulic lifters that are already pumped up and stock type stamped rockers I've had good luck either using a 3/8 speed handle, or choking way up on a ratchet, and very gradually/very slowly working the bolts down a little at a time. Eventually the shaft will bottom out on the pedastals and when it does, THEN I torque to spec in 2 or 3 increments to make sure I'm not being fooled. If the job is rushed and the bolts individually reefed on, something will get screwed up for sure.
Solids are easier!
Rich H.
Esse Quam Videri
[Re: moparman383]
#84967
07/08/08 12:47 PM
07/08/08 12:47 PM
i would be more concerned about the spring pressure that the hydraulic lifter being pumped up- unless of course your lift is so high that you bottom out a valve.
[Re: ZIPPY]
#84968
07/08/08 06:09 PM
07/08/08 06:09 PM
mopowergtx
Eastern Ohio
Thats how I've always done them myself. Watch to see when the shaft is tight on the pedastals and give a little bit more choked up on a 3/8" ratchet and never had a problem. I had my shafts on and off several times on my recent SB build and the first time I torqued them to 18 ft lbs and didnt like it. Went back to my old "feel" way. But I wouldnt be afraid on an iron head BB with the 3/8" bolts going to 25 ft lbs with a torque wrench. But anything over a little squeeze past flush on the tightening seems unecessary anyway.
[Re: mopowergtx]
#84969
07/08/08 06:36 PM
07/08/08 06:36 PM
some of you guys are putting WAY to much faith in those threads. but thats just my opinion.
#84970
07/08/08 07:16 PM
07/08/08 07:16 PM
Posts: 21,826 Kirkland, Washington
Pacnorthcuda
Crushing the shaft is a bigger concern, but I've been using 25ftlbs on BB for a long time and never had a problem.
