Help, Installing 73 Chager non-SE 1/4 window seals #849354
11/09/10 12:18 AM
11/09/10 12:18 AM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
I got the new 1/4 window seals today and want to install them. I don't see how to remove the old ones that are on the window. On the window it has a chrome strip, the new one is just the rubber. The rubber on the old ones is warped and not even sealing. It looks like its going to be hard to do.
Re: Help, Installing 73 Chager non-SE 1/4 window seals [Re: wh23g3g] #849355
11/09/10 04:12 AM
11/09/10 04:12 AM
md
mopars4ever Offline
mopars4ever  Offline
md
If I remember correctly. I bent the pointy tab outwards and pulled the seal out of the chrome. Then lubed the new seal and slid it in. Then bent the tab back down. It was a few years that I did it so maybe someone else will chime in.
Re: Help, Installing 73 Chager non-SE 1/4 window seals [Re: mopars4ever] #849356
11/09/10 11:11 AM
11/09/10 11:11 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
and don't expect the new seals are good like the old ones.
BTDT
