68 barracuda rims/ lug nuts. #849193
11/08/10 10:02 PM
11/08/10 10:02 PM
New York
Tom Lauricella Offline OP
New York
This is more of a generic question. I have a disc brake conversion kit on my 68. One of the wheel studs is stripped and there is no way of getting the lug nut off. Ive tried everything known to man.....minus flame. Aluminum rims :-/ Does anyone have any hints or tips on what works best? The nut is shot and the stud is just spinning. LET ME KNOW!!!!
Re: 68 barracuda rims/ lug nuts. [Re: Tom Lauricella] #849194
11/08/10 10:13 PM
11/08/10 10:13 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Anyway of using a dremel tool or a similar type tool to cut the nut length-wise, to split it?
codfish
Re: 68 barracuda rims/ lug nuts. [Re: Tom Lauricella] #849195
11/08/10 10:36 PM
11/08/10 10:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Did you try pulling out on rim/tire while you try spinning that stripped nut off at the same time? Worked for me once or twice. (You do this with other nuts removed already)
