1972 Chrysler Imperial Le Baron workshop manual #849091
11/08/10 07:09 PM
11/08/10 07:09 PM
Surrey, UNITED KINGDOM
Mr RUNNER Offline OP
Has anyone got a workshop manual for the above or can email a copy of the A/C wiring diagram as I can`t get the Fan to work to demist the front screen.
Re: 1972 Chrysler Imperial Le Baron workshop manual [Re: Mr RUNNER] #849092
11/08/10 07:25 PM
11/08/10 07:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the fan runs for the heater and a/c then you have a vacuum problem. If the fan doesn't work at all then it's probably the blower motor resistor. Here is a place to find the wiring diagram you need. http://www.mymopar.com/index.php?pid=24
Re: 1972 Chrysler Imperial Le Baron workshop manual [Re: stumpy] #849093
11/08/10 07:34 PM
11/08/10 07:34 PM
Thankyou, that is a great help, now I can trace out the wiring. When you say there may be a vacume problem will that be in the control box mounted near the R/H fender?
Re: 1972 Chrysler Imperial Le Baron workshop manual [Re: Mr RUNNER] #849094
11/08/10 07:47 PM
11/08/10 07:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When you move the controls from heat to a/c does the air change from blowing out of the heater vents under the dash to the a/c vents in the front of the dash?
Re: 1972 Chrysler Imperial Le Baron workshop manual [Re: Mr RUNNER] #849095
11/08/10 08:03 PM
11/08/10 08:03 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Does your Imperial have autotemp II? Or the regular setup?
