voltmeter #84898
07/06/08 05:02 PM
07/06/08 05:02 PM
East central Missouri
larryj Offline OP
larryj  Offline OP
Where is the best place to wire a voltmeter into the wiring. I thought I would wire it to the starter relay, but wouldn't it draw current with the key off? This is not an aftermarket voltmeter, thus no instructions.
Thankful for any help.
Re: voltmeter [Re: larryj] #84899
07/06/08 05:05 PM
07/06/08 05:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Hook the voltmeter to any keyed source of battery voltage.
Re: voltmeter [Re: John_Kunkel] #84900
07/06/08 05:59 PM
07/06/08 05:59 PM
larryj Offline OP
larryj  Offline OP
Thanks John...I thought it should be wired to a key activated circuit, but I was at a local car cruise last night and noticed a brand X car was reading about 12 volts with the engine off. Made me wonder.
Thanks again
Re: voltmeter [Re: larryj] #84901
07/06/08 06:07 PM
07/06/08 06:07 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Best way is to wire directly or as close electrically as possible to the battery (battery disconnect switch if you have one). That gives you the most accurate reading. Anything else will show a lower battery voltage because of voltage drop - - unless the circuit is not drawing any current.
