Stripped header bolt threads... #848966
11/08/10 03:04 PM
11/08/10 03:04 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Hey folks,
Had a header leak at the head, was tightening the bolt and stripped it *^()*%$#! Thought it was just the bolt, but using a new bolt in the hole didn't hold it. I retapped the hole, put in a new bolt and that didn't hold either...
Do they make slightly oversized self-tapping header bolts?
I'd rather not pull the engine to heli coil it.
Any other ideas?
Re: Stripped header bolt threads... [Re: T/A CARe] #848967
11/08/10 03:30 PM
11/08/10 03:30 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Which is stronger:
ARP Stainless Steel claiming 15% stronger than Grade 8 steel bolts
or
ARP Chromemoly 170,000 psi tensile strength bolts?
Re: Stripped header bolt threads... [Re: T/A CARe] #848968
11/08/10 03:35 PM
11/08/10 03:35 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Get a 3/8-16 heil coil kit and use the tap that is made for the 3/8 insert. If you want to go up a bolt size it will cause other issues and troubles installing it as well. Can you use a metric stud with sealer ?
logan426
