68 A-body park lamp ? #848729
11/08/10 11:22 AM
11/08/10 11:22 AM
Poplar Bluff, Missouri
partfiler69 Offline OP
Still Wondering
Still Wondering
On my 68 Valiant, when i turn my headlights on, my park lamps go out. Everything else works fine, I removed the light switch(it looked like it was recently replaced)and swapped it with one outta my 76 volare parts car, and got the same results. I thought this had something to do with the horrible repair job on the turn signals back in the day. The turn signal switch went bad, and someone cut the wires and put in one of those aftermarket switches in it. Well i replaced the switch with a correct Chrysler T/S switch, but still no park lamps. They work fine without the headlights on. Can anybody ?
Back from hiatus
Re: 68 A-body park lamp ? [Re: partfiler69] #848730
11/08/10 11:29 AM
11/08/10 11:29 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The car is working correctly for a 68
Re: 68 A-body park lamp ? [Re: buildanother] #848731
11/08/10 12:13 PM
11/08/10 12:13 PM
scratchnfotraction Offline
69 was the DOT law change for the turn sigs/marker lights on with headlights
your good
Re: 68 A-body park lamp ? [Re: buildanother] #848732
11/08/10 12:17 PM
11/08/10 12:17 PM
Still Wondering
Still Wondering
Thank you, now I can stop beating my head up against the wall.
Back from hiatus
Re: 68 A-body park lamp ? [Re: partfiler69] #848733
11/08/10 12:23 PM
11/08/10 12:23 PM
I did the same thing with my 68dart when I first got it
also drove me nuts looking into why the driver side brake light did not work
pass side goes thru it but did not work,worked with the pass side blinker blinking though
come to be the turn sig switch on the colum,handle hung down from age and would cancil the brake light but not blink yet
then I looked all over to figure out how the rev light worked...last place i would have thought to look was down on the lower part of the colum under the dash
and 68 was the only kool any kind of mopar with the bullseye side marker lights
have you went to the newer style solid state elect voltage regulator yet with the 1 wire 68 alt?
that was one of the best things I did to mine,that and pertronix points conversion in the dist
Re: 68 A-body park lamp ? [Re: scratchnfotraction] #848734
11/08/10 12:49 PM
11/08/10 12:49 PM
Still Wondering
Still Wondering
No, i plan to change over to the electronic style that looks orig, like what is advertised here on moparts, but workin 80hrs a week, i barely have time to put gas in her. I haven't even been able to do the electronic ign. upgrade (i have everything ex the dizzy). But it still runs like a sewing machine with the points. I have added a dual field alternator since the anemic original 30 amp wasn't cutting it. my needle spent more time on "D" than "C". But its my only project car that I get to drive while i work on her. Plus that 225 gets decent milage and still turns heads.
Back from hiatus
Re: 68 A-body park lamp ? [Re: buildanother] #848735
11/08/10 07:44 PM
11/08/10 07:44 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Correct for a '68 Valiant! '68 (maybe 67?) was a transition year. For example, '68 Barracuda, parking lights stay on. So you can find some '68 models with parking lights off, and others with them on.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 68 A-body park lamp ? [Re: GO_Fish] #848736
11/08/10 07:48 PM
11/08/10 07:48 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
This is a standard function of the '67 and '68 Barracudas as a styling choice instead of a safety thing.
Re: 68 A-body park lamp ? [Re: NicksGarage] #848737
12/03/10 04:40 PM
12/03/10 04:40 PM
Still Wondering
Still Wondering
Are there two wires that I can jump to get the parks lamps working?
Back from hiatus
