My wife left the ignition on.... #84831
07/06/08 02:34 PM
07/06/08 02:34 PM
Falcon, CO
71pettyblue Offline OP
Falcon, CO
...yesterday (at least 17 hours) on her '98 Durango, draining the battery, but that's not the half of it. I got the Durango to start with a jump from my Ram, but when I let go of the pedal, the engine dies. I'm assuming that the fuel pump was damaged and the Durango does not have enough fuel pressure to idle?
Any thoughts?
Tony
Retired Mopar Enthusiast
Re: My wife left the ignition on.... [Re: 71pettyblue] #84832
07/06/08 02:37 PM
07/06/08 02:37 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
The battery probably is so low that the systems are not functioning correctly...
Darren
Re: My wife left the ignition on.... [Re: DarrenS] #84833
07/06/08 02:39 PM
07/06/08 02:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
When you leave the ignition on, the computer will only power the fuel pump for a couple seconds to prime the system, then shut the pump off. Pump won't run continuously unless the computer detects the engine is running.
Modern EFI cars often don't run well with a dead battery when boosted. Throw the battery on the charger for an afternoon then put it back in and start it up. I'll bet it'll run fine.
Re: My wife left the ignition on.... [Re: DaytonaTurbo] #84834
07/06/08 02:42 PM
07/06/08 02:42 PM
None
71rm23 Offline
71rm23  Offline
None
Re: My wife left the ignition on.... [Re: DarrenS] #84835
07/06/08 02:42 PM
07/06/08 02:42 PM
Falcon, CO
Falcon, CO
I'll charge the battery up, thanks for the tip guys.
Tony
Re: My wife left the ignition on.... [Re: 71pettyblue] #84836
07/06/08 02:57 PM
07/06/08 02:57 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Happened to my Dakota once, it would hardly run. After disconecting battery for a few moments the computer reset itself and ran fine.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: My wife left the ignition on.... [Re: mopargem] #84837
07/06/08 03:29 PM
07/06/08 03:29 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Start and keep running at high idle with a good charged battery and drive it a couple of miles and let the system reset and you will be fine. Been there done that.
Re: My wife left the ignition on.... [Re: MoparforLife] #84838
07/06/08 03:48 PM
07/06/08 03:48 PM
P
Paul_Fancsali Offline
P
If the battery totally discharged you will need to reset the idle speed motor Place your foot on the gas and hold the brake tightly.literally do a brake stand only with a very lite throttle.May take up to 2 min to set do not overheat the trans. I have had to do this a dozen times on my 318 360 FI engines when the driver killed the battery
Re: My wife left the ignition on.... [Re: Paul_Fancsali] #84839
07/08/08 12:07 AM
07/08/08 12:07 AM
Falcon, CO
Falcon, CO
I put the battery on the charger for 5 hours and the Durango started and ran perfectly. Oh, my wife was trying to figure out why her Ipod wasn't working when she left the ignition on. Evidently, the key buzzer didn't come on when she opened the door.
Thanks to all who responded, I appreciate it.
Tony
Re: My wife left the ignition on.... [Re: 71pettyblue] #84840
07/08/08 07:26 PM
07/08/08 07:26 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Them dang'd 'lectrons make a run for it every time you leave the key on. The buzzer scares em back in. Fix it.
Re: My wife left the ignition on.... [Re: Vert] #84841
07/08/08 07:36 PM
07/08/08 07:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not I the same league as yours but my wife left the key in the on position on my new riding lawnmower and it killed the battery and put 80 hours on my time meter. Mike
