Dana 60 front seal question #848181
11/07/10 05:14 PM
11/07/10 05:14 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
The front seal where the yoke connects to the driveshaft is leaking oil and I was wondering if it can be replaced without removing the entire gear set from the rear. Can it be replaced from the front?
I hope I just overfilled it....but in case it's bad, I need to know what's involved to repair it.
Thx
Re: Dana 60 front seal question [Re: Texican] #848182
11/07/10 05:16 PM
11/07/10 05:16 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
yep, no problem to replace it.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Dana 60 front seal question [Re: bigtimeauto] #848183
11/07/10 09:42 PM
11/07/10 09:42 PM
NC
440Jim Offline
440Jim  Offline
NC
Yes,
It can be replaced no problem.
The pinion preload is set by shims, so just make sure to tighten it up (a lot).
