conveter slip #847923
11/07/10 11:40 AM
11/07/10 11:40 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
got my car running with pg today with spragless converter it stalls on transbrake 3000 and driving in top flashs to 4200 is that normal for spragless or is it a trans problem
__________________
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: conveter slip [Re: Ian] #847924
11/07/10 03:09 PM
11/07/10 03:09 PM
I don't know about spragless powerglide converters, my 10 inch Contintentl 727 converter would foot stall 2300 RPm before sliding the skinny front tires through the lights, it flashes to 4200 to 4800 RPM depending on which track, weather and motor that was in the car. It had 13% slippage at the finish line I had one 8 inch Dynamic converter that would foot stall 4200 (in a different car) and had right at 8 % converter slippage on the other end I hope this helps
Re: conveter slip [Re: Cab_Burge] #847925
11/07/10 10:47 PM
11/07/10 10:47 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
cab thanks seen the same thing with foot brake vs real stall, but not trans brake vs top gear stall
