Re: Injector Stack vs. SM Intake
[Re: tubtar]
#847904
11/07/10 01:19 PM
11/07/10 01:19 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Set up sits on a W7 small block I believe its a 440 cu in car ran inthe low 8's in a 3200 lb conquest, The entire motor is for sale, Very sad story a true mopar racer died of cancer his wife and best friend now are selling everything including Hemi Alum block, a complete 572 hemi block that has 440 heads, several race small blocks, also cars a 67 Barracuda just out of the body shop, a 65 Barracuda full tube chassis running a 440 with a pro charger best of everthing, never got to race car before he died, also a 67 cornet show quality with a Alumn Hemi never run. If any interested parties please let me know.
[Re: mokid]
#847905
11/07/10 02:15 PM
11/07/10 02:15 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Stack injection on alcohol will make more power than a carb on alcohol, and if you are starting from scratch, the costs is comparable. If the system came of a sprint car motor with W-7 heads, it will not bolt straight on a set of 440 heads.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: mokid]
#847907
11/07/10 07:55 PM
11/07/10 07:55 PM
Posts: 4,213 New York
polyspheric
New York
The IR throttles have to be really huge to beat a carbureted plenum manifold.
Boffin Emeritus
[Re: polyspheric]
#847908
11/07/10 08:54 PM
11/07/10 08:54 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
This kind of formed my opinion........they seem to start at 2 1/8" dia and go up from there on small block set ups I have seen........telling me that they will allow huge amounts of air in. And if you don't have the arrangement that requires this , a carb would be a better choice. Again.....purely guess work from my corner. But it seems to work on paper.
[Re: tubtar]
#847909
11/08/10 12:08 AM
11/08/10 12:08 AM
polyspheric
New York
That's not very big. Crower used 2.90" stacks on 427" BBC 40 years ago.
Boffin Emeritus
[Re: 40ford]
#847912
11/08/10 02:10 PM
11/08/10 02:10 PM
Slingshot383
St. Charles, MO.
The Indy 8-Stack is a 2.90" throttle bore, and Engler Machine and tool can make them much larger than that. A properly set up mechanical fuel injection unit will work at lower rpm's than 4000, and will also have a clean idle.
[Re: Slingshot383]
#847913
11/08/10 06:25 PM
11/08/10 06:25 PM
Challenger 1
Cincinnati, Ohio
I agree with the last 2 posters.
I have run 2 different stack injections and have out run all carbs.
I could see driving them on the street, no problem. I even used my N2O system to prime the motor to start,one man job. ![](http://i21.photobucket.com/albums/b260/challenger19711/Pictures%20taken%20after%20%209-7-10/MVC-024S.jpg)
[Re: 40ford]
#847914
11/08/10 08:46 PM
11/08/10 08:46 PM
polyspheric
New York
The IRs don't idle well and don't accelerate well off idle----they don't have an acceleration pump as carbs.
Backward.
Boffin Emeritus
[Re: mokid]
#847921
11/09/10 11:42 AM
11/09/10 11:42 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Ive seen guys do conversions where they have EFI injectors on the underside of the stacks , connect MAP to all of the stacks with small tubes on the outside to a miniature manifold and a TPS on one throttle shaft. Works really nice for the street.
8.30's @3400 lbs
