A-Body 383 motor?
#847855
11/07/10 09:46 AM
11/07/10 09:46 AM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
I have a 66 model year 383 that is factory drilled for the driver side motor mount that attaches to the front of the block. Is this exactly what was used in the 383 A-body cars? I also have the bracket. I plan to sell it and want to make sure I advertise it correctly. Thanks Tom
68 Charger 70 Cuda
Re: A-Body 383 motor?
[Re: FC7cuda]
#847858
11/07/10 10:36 AM
11/07/10 10:36 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
Thanks Tom
They didn't put big blocks in A bodies in 1966 , but you knew that. that is the C body mount point as mentioned.
Every 383 before 1970 has those nubs and prior to 68 they were ALL drilled and tapped, only select blocks destined for A body usage were drilled and tapped and one other operation performed to the block. That block should not have had that extra operation so it's obviously not an A body specific block that will garner you extra $$$, assuming that is your thinking. this is of course assuming also it's not stamped as a 68 or 69 model year which is possible , but highly unlikely, given the shear volume of 383 cars built during that era.
[Re: JohnRR]
#847859
11/07/10 12:37 PM
11/07/10 12:37 PM
FC7cuda
Dallas, Texas
Yes, since it was used in 66, it's not a "real" A-body 383. What I'm trying to determine is if it will mate/fit correctly in a A-body so long as the correct K-frame is used. Here's a pic of the bracket.
Thanks again...
68 Charger 70 Cuda
[Re: FC7cuda]
#847861
11/07/10 01:01 PM
11/07/10 01:01 PM
JohnRR
Thanks again...
Yes it will work with the right K frame
[Re: Rhinodart]
#847862
11/08/10 05:55 AM
11/08/10 05:55 AM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
The only difference in the block will be that the rear motormount boss on the drivers side will be shaved off for an A-Body.
Is this the extra operation performed to the block? I wonder why they shaved the mount off. What did (or would have) it hit/rubbed?
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
